Old 08-18-2014, 12:13 PM
Husker Husker is offline
Thanks Moparman, sounded like a workable troubleshoot to me.
J-Mech, whats the rationale in NOT pursuing this method?
So far I've done a bench test on the s/g. All sat.
Solenoid was bad. Waiting on the replacement part.
First I want to get it started. Then troubleshoot the oil issue.
To test if the engine was seized up I removed the plug, put a plastic guage in the plughole and hand spun the engine to see if my piston was moving.
Old 08-18-2014, 12:50 PM
Here's the rationale broken down for you:
Originally Posted by moparman849 View Post
Pull the starter belt turn the key if the starter spins it's good
Maybe. Still could be a bad S/G. Even with a bad field it will spin when not under load.
if not its electrical
More than likely. A mostly obvious statement
then unbolt the motor and the drive shift and try to turn the motor
True. Good next step.
if not pull the oil pan and the head put some thin oil on the top of the piston let Sit and and try to turn the motor
Oil alone will not break free a seized motor. If the piston is scored it would do nothing.
when it comes free pull the piston and have the crank spun measure for a new connecting rod
Yes, if it comes free take it apart. You do not have a crank "spun measured for a new rod". You grind the crank. Period. Every time you rebuild a "K" series Kohler. Then you buy a rod to fit the crank, or have a bearing insert installed.
then put a new piston in it look on the cylinders see if there is any starring if yes get bored and Sleaved
You do not install a new piston and then check the bore. You bore the block to accept a new piston. Sleeving is an expensive option. Yes it can be done, but usually you can buy another block cheaper.
Here is a link to the wiring diagram for you tractor. Should only take a few minutes to figure out why it won't crank. Then, pull the engine. I promise, it's shot. Engines don't recover from running out of oil.
Old 08-18-2014, 02:09 PM
Great break down and explaination. Thank you.
Old 08-18-2014, 02:24 PM
rwairforce rwairforce is offline
That sure sounds like a lot of experience talking. I'm not a Las Vegas gambling type but if I put a $1 on it I'm going with J-Mech.
Good luck. Worse case, you end up with a 149 with a rebirthed engine. Not all bad.
Randy
Cubs: 71, 72, 127, 149, 1440, 2186 and 1864
John Deere 110 round fender
John Deere 140 H3
Sears: GTV16
Old 08-22-2014, 11:57 AM
Time to rebuild the engine. Its about the end of the season I normally use it, so I have some time to tear down and rebuild. This will be my first solo rebuild, any tips on what to expect and look for as I dig in? I have helped tear down and rebuild a 350 chevy so I won't be going in completely blind, but that was merely helping an experienced mechanic and picking up what I could along the way. What specialized tools will I need (gear puller? valve spring compressor? cylindar hone?).
To get my rebuild kit I need to provide piston and rod size, will I need to take apart the engine first and determine if it needs bored to get these measurements or do I get it bored (if necessary) to fit the piston/rod I purchase?
Standard cylinder bore.........3.500"
+.010 ....................................... 3.510"
+.020.........................................3.52 0"
+.030.........................................3.53 0"
Standard rod...........................1.500"
-.010...........................................1.4 90"
-.020..........................................1.48 0"
Do I get add ons as well when I take it down, or are they an unnecessary cost?
Crank bearings
Valve guides
Govornor gear
Steel points plunger
Thanks for your help and I welcome any input ya'll have.
Old 08-22-2014, 01:00 PM
Only "special tools" you need is a valve spring compressor. You can probably to it without out it, but it's easier with. Probably need a 3 jaw puller. No need for a cylinder hone. Probably ought you at least have access to a dial indicator so you can check crank end play, it has a spec.
Tear it all down, and take the crank and block to a machine shop. They will measure the bore and tell you what size piston you need. They will grind the crank and tell you what rod you need. THEN you order the kit. Not before, but after you find you what size of piston and rod you need. Crank bearings can be re-used as long as they are not damaged. Valve guides are seldom wore out. Let the machine shop bore the block and fit the new piston, grind the crank, and grind the valve seats and install the new valves. Then you do the rest. Do not hone the cylinder and try to do all above work yourself. That's what machine shops are for. Steel points plunger is unnecessary IMHO, governor gear.... your choice. If they look OK, I use them over. Some people swear by replacement only. There are no "add on's" that I can think of you need. Download the service manual and good luck.
Tags
149, no start, smoke
