I start with 180 and once I get close I finish with 220. When your done it should look the same on all the contact area.
Did you install new valves? Where'd you get that red valve spring? |
Those are the old valves, I just cleaned them up.
The red spring on the intake was there already.
- Tim 1872 60" Haban deck- 2082 450 blower, 50c deck - 1450,1650 2x44a deck, QA-42A snowthrower, 70 w/k181(destroyed) 38" pin on deck |
Huh. Never thought of using a magnet on the valve to hold the keepers on before. I always just lubed them up with oil or grease and got them to stick to the valve. Pretty good idea!
1966 Cub Cadet 122 1968 John Deere 110 1968 Cub Cadet 104 1971 Cub Cadet 107 1975 Cub Cadet 1650 2 Brinly Plows, Brinly Disk, Brinly Grader Blade, Brinly Box Blade, 3-42" decks, 1-50" deck, a Sears 3 pt hitch I bought for $20, a couple dual wheel adapters, CW36 & QA36 snow throwers, 1A tiller, and a partridge in a pear tree. |
Thanks, I used the dab of grease method on the first valve but space was so tight on the second that I tried the magnet.
