Old 09-07-2014, 05:50 PM
Jonah Close's Avatar
Jonah Close Jonah Close is offline
I just cleaned out the generator, cleaned the brushes, commutator,etc. Now upon some more testing I am now getting 26.5 volts at the battery but the amp meter still reads zip. I jumped the generator output directly to the battery through an amp meter I had on hand and It read about 15 amps. So maybe my regulator or my wiring harness is screwed up??
Thanks!
Old 09-08-2014, 10:15 PM
Just bringing this back up...
Old 09-09-2014, 12:33 AM
I'm really doubting the reading you got. The gen isn't capable of that kind of voltage. 17V maybe 18V max. Test again. Make sure your DVOM/VOM is set on the correct setting, and working.
Did you do the test that Roland linked to in post #10? That pretty much should have told you what component is bad. FWIW, if your dash ammeter isn't moving, you may just have a bad ammeter. If failed, it will not let voltage through to the battery. Just like a switch in the "off" position.
