Old 09-06-2014, 06:58 PM
cubs-n-bxrs's Avatar
I guess I would take the points off and clean up the mounting surfaces on the block and the back of the points. Reinstall and check again for spark. Over time the surfaces will become oxidized or get oil on the surfaces causing a poor connection.
Old 09-10-2014, 06:22 PM
Toolbox91 Toolbox91 is offline
Alright well an update. I ordered a harley davidson 12v dual coil off ebay for $50. Worked like a charm and fired right up. Ran it for a few minutes then went to tighten everything up on the coil since i only hand tightened everything. Wham, the negative post on the coil twists apart by barely turning it with a wrench. So in short the coil was my problem. Now my problem is luck.
Old 09-12-2014, 07:56 AM
SGragg SGragg is offline
Inactive Member
But at least there's some comfort knowing what the problem was...
Stanton
1980 IH 782, Kohler M18
IH #1 Cart, original
2015 XT2, Kawasaki 23 HP
