Old 09-23-2014, 06:53 PM
Originally Posted by offroadodge View Post
thank you, the hydro lift pump for the tiller leaks a little so I may look into rebuilding it. Does anyone know if there is a rebuild kit for this? and I have looked but cant seem to find any ID# at all.
I am not for sure, but I believe that the local NAPA store will rebuild it. I know that they build/make the hoses for it. Find out where it is leaking, first. If it is the hoses, then that should be somewhat of an easy fix.
Old 09-23-2014, 07:21 PM
I've not ever seen a napa store that rebuilds power steering pumps..... (which is basically what that lift is.) Actually...... AFAIK, no Napa store rebuilds anything anymore. They can send some things off and get rebuilt, but that is outside of "Napa".
To the OP:
Not many parts out there available for those units anymore. Your pretty much on your own, unfortunately. Find a hydraulic shop, or attempt it yourself is about your only options.
Old 09-23-2014, 08:54 PM
offroadodge offroadodge is offline
I believe its leaking from the front shaft seal. Not crazy bad but a few drops in 2 days. Pulled the wheels off last night and brought them to work to remove the tires and refinish the rear wheels. I should have some lug tractor tires here this Friday. Gonna paint the wheel tomorrow at work.
Old 09-25-2014, 06:21 PM
Got a few things done today
Old 09-29-2014, 04:22 PM
Got the rear wheels done
Old 09-29-2014, 04:58 PM
TheSaturnV's Avatar
Nothing like fresh tires and newly repainted wheels. Coming along!
Old 09-29-2014, 05:15 PM
Merk Merk is offline
To the OP:
My local Napa store rebuilds starters, generators, alternators, heads and some engines. They turn brake drums and rotors too.
If a crankshaft needs undersize it will be sent out.
Project Uncle Dick
Cub Cadet 70
Old 10-02-2014, 10:54 PM
does anyone know where I can get the transmission control handle and the shaft?
Old 10-05-2014, 12:08 AM
Got the 149 today and the price was right.
Old 10-05-2014, 12:24 AM
tonka.scout800a tonka.scout800a is offline
Nice 149....
Everything I find within a couple hundred miles the seller thinks its gold plated.
