Old 09-25-2014, 05:03 PM
Berwil's Avatar
Berwil Berwil is offline
How about a "knock down" on the deck chute to keep the grass within 24", then mount the sweeper like a side car on the discharge side. Mow and sweep at the same time.
Bill
Did you guys see post #6? Just wondering......
Old 09-25-2014, 05:48 PM
You can't hook Agri-Fabs up like that. Look at the hitch design. When mounted to the tractor, there is (supposed) to be a spacer in the hitch. The tongue actually pics up on the tractor. In other words, when you hook up, you have to press the tongue down to hook it up. This lifts the sweepers bag off the ground. If the hitch you make to pull it isn't heavy enough to push down on the tongue, then it's hitch will just pop up in the air and the bag will be on the ground. The tandem hitch will have to be very heavy, and have wheels on it. Then it would work.
That has nothing to do with my Red Green alternative. ...
Up to 534 and counting...
Old 09-25-2014, 06:12 PM
Just get AC to sweep the lawn, he loves running his sweeper.
It will be a cold day in H--L before I sweep my lawn. God wanted those clippings where they are so I'm gonna leave them.
Old 09-25-2014, 06:30 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
A hand held leaf blower mounted red green style would do the job, then when you get a big enough row, go to the sweeper.
I like it!
I may attempt this when the leaves begin to fall. Got 4 rolls of "the handymans secret weapon", I think I can make it happen.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 09-25-2014, 06:55 PM
I like it!
A leaf blower on wheels does the same thing,works for grass too.
Old 09-25-2014, 07:24 PM
Just my 2 cents, I cut it and where it lands is where it stays. Granted it does not look like a golf course green but I don't care.
Old 09-25-2014, 08:00 PM
Berwil's Avatar
Of course, mine is the same way, just need a caster under the rear of the bag to support the weight. We call that "low hangin fruit". LoL
Bill
Old 09-25-2014, 08:16 PM
Bill
Even if it had a caster under the bag it wouldn't work. Unless you mounted the caster to the frame and not the bag. Then it would.
Old 09-25-2014, 08:54 PM
jimbob200521's Avatar
Actually...no I didn't, not until you pointed it out. You posted at almost the exact minute I did so I didn't even think to scroll above my post to read responses
That being said, I see what you're saying. It shouldn't be too hard to make an adjustment to the design to accommodate what you said. But, while it may may be a fairly simple solution (add weight to the central hitch and a caster or two to keep it off the ground), it will cost more money. I'll see if I can think of something, hmm...there's go to be a simpler way to make this work
-Ryan
