Old 10-01-2014, 11:13 AM
I will try to shim them with aluminum from a coke can.
I like that idea.
Old 10-01-2014, 11:22 AM
If you drove the old ones out...... I doubt the issue is with the hub.
Old 10-01-2014, 11:30 AM
Steve149's Avatar
Steve149 Steve149 is offline
X2
Old 10-01-2014, 11:50 AM
On mine, on one side they fit just fine with a swinging press, on the other side it was obvious someone had run a wheel bearing out at one time, opening up the hub slightly. There are some marks ground into the bottom of the spindle on that side also. I had thought about welding it up, because $56 for a new wheel is just too strong for me right now. The spindle got emery, the hub got epoxy, its all good now. It's a tractor not a space shuttle.
Old 10-01-2014, 11:58 AM
Well I don't disagree with that at all!!!
Old 10-01-2014, 12:08 PM
Wow......
some of you guys are really crude. I'd be pretty frustrated buying a tractor and finding JB weld glueing the now bad wheel bearing in. So will you when they need changed again.
Since you bought them off e-bay, I'm going to assume that they are the cheap china bearings. And it surprises you that they don't fit right?......
LOL, I agree Jonathan.
Old 10-01-2014, 01:00 PM
rwairforce rwairforce is offline
That is an excellent observation. I totally agree.
Randy
Cubs: 71, 72, 127, 149, 1440, 2186 and 1864
John Deere 110 round fender
John Deere 140 H3
Sears: GTV16
Old 10-01-2014, 02:27 PM
mortten mortten is offline
The aluminum tape worked well for me also. If you can fit a piece of pop can all the way around that's pretty far out of wack.
Old 10-01-2014, 04:30 PM
Mr Bob's Avatar
Mr Bob Mr Bob is offline
Smile 149 wheel bearings
Used the coke can metal for a shim. Bearings were a little tight bur was able to use a hammer and a socket to fit the outside of the bearing and they went in ok. Wheels roll freely so I don't think I hurt the bearings. Thanks again for all the responses.
Old 10-02-2014, 09:29 AM
yeeter yeeter is offline
A space shuttle you say, hmmmm.....
