Old 10-10-2014, 11:04 AM
Don't some pumps have a splined shaft for the drive shaft, and others have a non splined shaft? He would want one without the splined shaft, correct?
Yes that is correct, but those units are the later units after Sundstrand was bought out by Sauer/Danfoss. FWIW, I'm almost 100% sure you can swap the shafts if you absolutely needed to. Unless you have a unit laying around that you wanted to use, there is no need to though. The hydro units are sooooo easy to find.
Old 10-10-2014, 11:41 AM
NOT the IH specified Sundstrand Units. As stated previous, they used three.
Old 10-10-2014, 02:52 PM
Make sure you don't get one for a SGT, the output shaft is different and it won't work on your 1250.
Here is one on Flea Bay. http://www.ebay.com/itm/Cub-Cadet-14...item3f3b2ebc7b
Give the sponsors at the top of the page a call, I'd bet they have a few.
Old 10-12-2014, 11:11 AM
Mr.Goffena's Avatar
Mr.Goffena Mr.Goffena is offline
I picked up a free john deere 318 hydro pump. So i took the front cover off with the ports and put it on a non ported cub pump i had laying around. I have not used it yet but everything went together just fine.
107 with rear lift
1250 hyd lift. 682 diesel project
Original project
#2 and tiller
#2 trailer
59M sheader
home made boxblade
wideframe 54" snowplow
Old 10-12-2014, 01:04 PM
Yes, the pumps are the same and you can do that. Hope you just used the cover, and not the brass valve plates.... If you do that, you should keep the valve plates with the pump they came from.
Old 10-12-2014, 03:36 PM
Mr.Goffena's Avatar
It is good that you mention that in case anyone does this. The brass plates need to stay with the rotating group that they were removed from. Switching them could cause internal leaks and premature failures.
107 with rear lift
Original project
#2 and tiller
#2 trailer
59M sheader
home made boxblade
Old 10-12-2014, 08:01 PM
Yeah..... that's what I said.
Old 10-18-2014, 10:27 AM
OldCubby
Don't know if you are still looking for a pump but one of the members has one for sale. Link to his ad.
http://www.onlycubcadets.net/forum/s...788#post291788
