Old 10-18-2014, 12:35 AM
john hall's Avatar
John, if it's the pump, take it off and run it without it. As long as the tank is above 1/4 full it will flow to the carb. I ran an 1811 for 2 years without a pump and never had a problem, but my land is also flat too.
We're probably too hilly for that unless I keep the tank half full. Engine might blow next time I use it but right now its well worth buying a pump for. The carb needs to be pulled off for a good soaking, it has a bit of a surge sometimes. A new set of points and condenser should be in order as well. I'm dragging my feet on this for a couple reasons; got other grass whacking machines and also I don't want this thing back in the shop tore down while I've got farm work yet to do.
Regarding Ethanol fuel, I'm pretty certain what I'm running is ethanol free, we buy it in bulk for the farm. And I'm certainly on the bandwagon that there seem to be a lot more fuel related repairs in the past few years based on what I've seen brought to my dad to work on. Used to the only fuel repairs were from worn out carbs, dirty fuel, or fuel that was left in an idle machine for a couple years. To paraphrase Forrest Gump, that's about all I have to say about that.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
