Congrats on the super, Lew.
Thanks.
What idiot lights are suppose to come one when you turn on the key? Its starting to grow on me.
Up to 534 and counting... I give up updating my profile! |
Lew
If I remember just the oil light will come on if you just turn it to run. If the fuel is low that should also come on. When you go to start it the depress left pedal light will come on if you haven’t pushed the pedal down, also the reverse light will come on if it’s in reverse but you can’t push the pedal down with it in reverse (seems kind of redundant to me). The disengage PTO light will come on if you try to start it with the PTO switch in the on position. If you want a copy of the service manual for the Cyclops send me your e-mail address in a PM and I'll get it to you. You mow with that bad boy once or twice and you'll be spoiled. ![]() Think you did OK considering that it had a list price of around $8900.00 back in the day.
seems like none of them work.The rev switch had its dingle dangle clipped off so that does not work.
They must have go up a few $$$ since this ad.even though it is a 2082
is this the one you were telling me about that were trying to get for a few years?
127 - 48'' deck + tiller. 1512- 46" GT deck & bagger 1872- 60" Haban 1772 turbo diesel- Iron rear + KW loader + backhoe + 3 point. Case 580CK Ford 850 International TD-8E |
Hi Ken,
No not this one, Need a 2284? hehe. I fooled around a little today with it ,The bulbs were tested on the dash and they work,I see some cut wires and new fuse holders,not sure what was done. I am surprised the 2284 was pretty clean in the hydo area,do you think with 951 hours something will be going on it soon?
Lew
They have a solid drive line. Clean oil and filter for the hydro and a couple shots of grease in the CV joints every year and you will become a believer. No more rag joints or shake rattle and roll. Trust me you got one of the last of the best. Holler if you have any questions. You can sit back, tilt the steering wheel and cruise like a Joisey Boy, a cold one and a stogie and you be stylin.
The cut wires and new fuseholders may be part of that CC sponsored wiring update to eliminate false alternator lights when the charging system is working ok and also to prevent the starting problem that causes to solenoid to just click and not start. I ran across instructions on the mods while researching wiring diagrams on another model.
1989 - Cub Cadet 1772 1987 - Cub Cadet 1572 w/Rear PTO & Cat. 0 38" Lawn Sweeper #196483 42" L42 (Bush Hog) Rotary Cutter # 190349 45" 2-Stage Snowblower # 196364 48" Haban Rotortiller Rear PTO Driven #190356 54" SnowBlade with hydraulic Angle #196376 60" Haban Mowing Deck #196374 |
Frank,
I would like to see the info about the wiring. I assume it probably includes the Kubota powered models? My 1782 has the false alternator light problem and it drives me nuts. It also had the click problem with the starter, but I haven't experienced it since the upgrade.
2 Originals, 100, 105, 125, 1450, 1200, 2 IH 982's, 1211, 1872, 2072, 2-1864's, 1782, a few 42" front blades, 2 Haban 54" blades, Haban sickle mower, BB36, QA-36A, 42" IH rear blade, 42" IH landscape rake, #1 tiller, #40 box blade, 59M shredder, #2 cart, International 3312 push mower, International 250 power washer, 1952 IH refridgerator, 1971 IH 1210 3/4T 4x4 truck
I changed the oil and filter today,fixed the lights,still have to hook up the low fuel wire,but I am still not getting the oil light to come on,cleaned the contact on oil sensor,but nothing. Does it come on only when low on oil?Dumb question.... I know the 1811 I had,the light would come on always when I put the key in the run position before starting.
