Old 11-07-2014, 08:16 PM
moose007's Avatar
moose007 moose007 is offline
Default could not wait
Here is what it looks like now. I could not wait to show you my find. It is farm fresh but will work for this first winter then it will get overhauled next summer!!
1967 IH Cub Cadet 125 w/ hydro lift, hydo option in front, 3 pt, and 38" deck
Old 11-07-2014, 08:58 PM
Originally Posted by moose007 View Post
I got the plow mounted on the tractor now. I will Fab up some kind of bracket in the next week or so. I was looking at the lift rod and it does not seem to interfere with the hydraulics. It seems like it is a little short to make it inline with the foot rest rod and the lift arm so I might have to do a offset hole to make it work. I am not sure if it is the correct lift rod or not .
Thanks for the pictures and ideas. I will post more pictures when it is complete.
I have a 125 with hydraulic lift and I made an offset mount to use the factory lift bar.
https://www.youtube.com/watch?v=tfWy8jbj_GY
You can see it at the :04 mark
Old 11-08-2014, 10:32 PM
alleycat alleycat is offline
Default front blade
Where did you find the blade? Would like to have one for my 149
Old 11-10-2014, 09:34 PM
Not trying to hijack this thread, but how do the front hydraulics on that set-up work? Do you have to move both levers at the same time to get the fronts to work?
Old 11-10-2014, 09:48 PM
RedHawCadet RedHawCadet is offline
It looks like the bottom valve is plumbed into the pump, just making it remote to the front. And the factory lever for the rocks shaft. Obviously both running off the same fluid. Just my thoughts...
Mark
1971 Model 73 - Hydraulic lift,Fenders,Creeper,Lights,Sleeve hitch and Weights
1967 Model 102- mower
1965 model 70 - weights,rear lift and spring assist
Model 100 resto mod project, rear PTO, hydraulic lift
QA42 snow thrower
42in front blade
Grandpa's F-12 and Super M
