Old 11-12-2014, 08:36 AM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
They have "trails" in Iowa?
Best spot for antenna is in the middle of the largest steel surface on your vehicle. Typically the middle of the roof.
If your trail riding with others, the FM walkie talkies would not work with but one other person?
Old 11-12-2014, 08:54 AM
You can talk to as many people as have the FM walkies. You set the channel just like any other radio. Anyone on the same channel can talk.
Old 11-12-2014, 11:52 AM
bruce s's Avatar
bruce s bruce s is offline
Yeh they have trails . MIOBI.org the make it or break it 4x4 park.
Old 11-12-2014, 08:21 PM
riesedesperado6170's Avatar
riesedesperado6170 riesedesperado6170 is offline
I get a Uniden Bearcat PC68LTW that what I run works good there like 90.00 or less
Old 11-13-2014, 08:09 AM
bruce s's Avatar
Thanks I'll check them out .
Old 11-13-2014, 09:11 AM
dyt4000's Avatar
dyt4000 dyt4000 is offline
If you like the idea of a Firestik, check out Wilson Silver loads...
Co-Founder
You only need two things in life...duct tape and WD-40
If it's stuck and needs loosening, use the WD-40.
If it's loose and it's suppose to be stuck, use the duct tape.
