thanks for your reply I did get it going this morning I waited a little while for it to warm up and then the hydraulics worked well I got it in the garage drain the oil it was a little bit milky but not bad changed the filter and works much better now much much better what a job I had getting the oil back into the rearend . I had to find a different kind of funnel to get it all in there. What a job
John
What some people do is to remove the dip stick tube then get a long funnel that will reach down into the case and fill it. They can be a pain to fill otherwise. Just make sure everything is clean before removing the tube so you don't get dirt into it. Here are a few threads on the Cyclops series tractors like yours. http://www.onlycubcadets.net/forum/s...ad.php?t=33244
Thanks finally got the oil in. Jammed a small funnel in the dipstick and poured it in. Tractor works great now
