Installed new belt yesterday but no new snow yet to try it out. Old belt looked fine to me, though. I have always wondered why the belt is so difficult to put on (and remove). Maybe it is ok but it is really a tight fit. The mower deck belt goes on much more easily and I've always wondered if something is wrong that the snow thrower belt goes on so hard. Anyone else see this?
I also noticed there is some play in the area I circled in the attached picture of the PTO pulley. About 1/8" maybe. It may have been there in the past and I didn't notice. Is this a cause for concern? |
To my knowledge- having some play there by the spacer is not an issue. All that spacer does is keep the body of the PTO from spinning andtaking the wiring with it(ask me how I would know that)!!!
As other have mentioned- if your engine rpms stay up and the Blower bogs-its either the belt of the PTO itself. Since you just did the belt...theres only 1 thing left. Chris |
I had a problem with the snowthrower on my 1572 during the Thanksgiving Day storm we had. 1/2 way done with the driveway, I heard a metallic clink when I raise the thrower at the end of the drive to turn around. I started on the way back up, and right at the end where the soggy burms are from the plows, the thrower really bogged down. I went through that and then didn't think much of it until I was by the mailbox when the thrower just about stopped spinning. Just as I was about to get off of the tractor it all started working again. It wasn't till I was done and inspecting everything, that I found the belt tensioner was bent into a pretzel shape. The belt developed a flat spot because of the extra slipping. How is the belt tensioner on your thrower? 15 or 20 minutes with a torch and mine was as good as new all straightened out.
1989 - Cub Cadet 1772 1987 - Cub Cadet 1572 w/Rear PTO & Cat. 0 38" Lawn Sweeper #196483 42" L42 (Bush Hog) Rotary Cutter # 190349 45" 2-Stage Snowblower # 196364 48" Haban Rotortiller Rear PTO Driven #190356 54" SnowBlade with hydraulic Angle #196376 60" Haban Mowing Deck #196374 |
...and the unit performed very well with the new belt. Threw snow like it did when it was just a cub. Wait. It is still a Cub. Anyway there's more in the driveway waiting for me when I get home!
I'm wondering if something on the blower isn't starting to seize up. Maybe a bearing or gearbox going bad?
That's all I can think of for now. Please if anyone has more, please chime in.
If the spring fell off, that sounds way too loose. When I have to set the tensioner on my thrower, it takes either a wrench or 2 hands on it to get it to the set position. In the 25 years of running this snow thrower, the spring has only fallen off once, and that was only because the hook on one end cracked off due to a defect/fatigue in the original spring.
