Glad you got it going!
![]() Quote:
as promised heres a few pics. J this seems weird to me the other wire on the plug is the sense wire i hooked this to battery POS terminal instead of the lug rite at alt. have noticed the back of alt. is warm not hot when it isnt running if i unhook this wire and wait a few hours its all cool. have unhooked the neg terminal on the battery with this wire hooked up and it wont lite a test lite so i dont think there is a draw on battery... at least not enuff to lite a test light. have also noticed the alternator works just fine with this wire unhooked. what would you do leave it unhooked. anywhoo heres a few pics
982D kwik-way loader w/3 spool control and front and rear remotes,2182, 1812 cat 0, 1440 puller, 3185 grass killer, 2x 450s, QA42, 364, tiller |
I went off a pin out I got off of the net for that alternator, so honestly I was guessing that it needed battery voltage on that pin. Most GM style alternators do.... If it works with it off, and the alt stays cool when it is, I'd leave it off.
sounds good to me thanks again J
I found these. This spiked my curiosity.
1966__122 Cub Cadet. Owner: Calvin, 6 yrs old Dad: Craig |
thats why i ran the wire all the way to the battery
Yep. And that's a GM alternator. I agree with the diagram. I can show you one where the second wire is ran to the output terminal of the alternator. (Hope that makes sense.) I am not too up on my Japanese alternators..... LOL. Like I said, if it works, I think your fine. If you want I can research it more.
I just worked on a Kioti the other day. Had a the same alt you just put on yours on it with the v-reg bypassed. It was wired like you did yours. One wire from the key, one to the battery. I didn't look at it, as it came in for a head gasket repair. I kinda fumbling here..... if you hooked up a test light and checked for draw and there was none..... you also disconnected it and it still charged.... I'm not sure that it matters one way or another.
I just got my alternator hooked up tonight. I was able to use the same belt so no taking out the driveshaft. This is a Denso style alternator. All you need to hook up is the charge wire on the lug and a switched 12v to the IG terminal to excite the alternator. The other terminal is only needed if you want a charge light. This is how mine is hooked up and it charges great.
1450 w/ 44gt deck, 1572 w/ 50C deck, 450 snowblower. |
