Old 12-11-2014, 06:05 PM
I installed roof louver vents in my garage roof last summer (2013) and with the doors open it makes a world of difference.
Old 12-11-2014, 08:17 PM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
I don't suggest plugging up your tanks with visqueen. Good way to create pressure on the tank. If you don't close the valve, it will just vent the pressure through the carb and force fuel out. If you do close it, it will just expand and pressurize the tank. Good way to make leaks, or worst case bust a tank. They are vented for a reason. Not just to allow air in as fuel is consumed. Plastic gas tanks will vent if pressurized enough. They aren't air tight.
I still say open a window.......
I have long term stored gas with visqueen under the caps for years without consequence. And in Michigan too with temperature swings of 20 below to 70 above. It must of pushed fuel out thru the carb without notice.
Old 12-12-2014, 10:24 AM
rdehli rdehli is offline
I cracked a window about 1/8 of an inch yesterday, what a difference. Will have to start doing that every few days or so to get some fresh air in the building. I think my problem is that I have no air movement, and that the air gets stale
