Old 12-18-2014, 04:05 PM
overtime hank's Avatar
overtime hank overtime hank is offline
Mike the wife keeps me in check in a good way
But at the same time its killing me not to able to work on this 102 after just buying it. This is why I am asking such broad termed questions.
Old 12-18-2014, 04:19 PM
Since we are talking about wives as much as Cubs I'll add that I was married to the B---H from H--L for 37 years, she checked out, life has been good ever since. First wife would have loved it if I filed for a divorce, no way she was going to get 1/2 of everything I worked for all my life, I out lasted her.
Married a Southern girl this year Happy, Happy, Happy. Just wish I had met her instead of the first one.
Old 12-18-2014, 05:59 PM
Ive bought 7 tractors in 10 months ,all different ,some junk for parts regardless she doesnt go out there much. Shes really a keeper I'm not throwing her back Just running out of room.
This is my first clutch repair ,starts up in gear and takes off, if not in neutral. Motor sound great, oils like honey,tractor doesn't look bad either.
Old 12-18-2014, 06:04 PM
Just figured out how to post pics. These pics are with clutch pedal down.
Old 12-18-2014, 06:25 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
That's a nice looking 102!!
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 12-18-2014, 06:57 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
first I'd make sure the brake rod going to the brake lever is there. then make sure the pivot where the rods hook on don't have a sheared pin. also look to make sure the adjusting bolt isn't back out or the push rod missing. if that looks good then its probably the puck seized in the reduction housing or the pivot pin seized. there's not allot to them. look at a break down in a parts book or manual and its pretty self explanatory . if all looks good I had 1 tractor 1 time where the brake disk on the front of the pinion where the disc broke from the splined center.
Old 12-18-2014, 07:14 PM
I looked at the 102 manual and it looked internal.Just look on parts tree looked simple. Again I havent been under it yet., makes me think of the worst.thanks for having patience with me.
Old 12-18-2014, 07:47 PM
Nice 102,looks like the clutch plates are stuck together.push down on the pedal and lock it.Then use a putty knife to separate the clutch plate from the drive plate.
Up to 534 and counting...
Old 12-18-2014, 09:06 PM
Originally Posted by overtime hank View Post
she wont complain cause Im going to get her a extra good gift to make up for my addiction.
You could tell her you got her a pretty nice 102...
Brake rod might not be hooked up...
Old 12-19-2014, 06:32 PM
PaulS's Avatar
PaulS PaulS is offline
I have 2 102s. Yes they are internal brakes. It is a little bit of a job to get to the very inside brake puck as you have to remove a wheel, cog, to get to the very inside puck. I have found the very inside puck doesn't seem to wear very much. The outside puck is easy to replace. IIRC there is a ball between the puck and the adjustment rod. Do not lose that ball. Also when you adjust the brakes, do it in very small increments as a little adjustment means a lot of brake difference. Good luck with your project, we are all counting on you.
