No, then the other end wouldn't match. The joints are made with same sizes on both ends.
were it mine i would drill all the way thru tap it out and countersink the back side to thread one bolt in from the back side so i would have a stud sticking out to put the rod end onto. that is if the threads were wiped out enuff just to put a longer bolt into it
982D kwik-way loader w/3 spool control and front and rear remotes,2182, 1812 cat 0, 1440 puller, 3185 grass killer, 2x 450s, QA42, 364, tiller |
I agree with the above ideas. Clean out the hole, use a new bolt, loctite it, and see if it tightens down first.
![]() Quote:
![]() Quote:
If you really want a heli-coil in it, I can do it for you. Something to remember about heli-coils is that they will usually only be 1.5 times the diameter of the bolt or in this case 3/4" and stacking them doesn't always work too well.
2 Originals, 100, 105, 125, 1450, 1200, 2 IH 982's, 1211, 2072, 2-1864's, 1782, 3 - 42" front blades, 3 Haban 54" blades, Haban sickle mower, BB36, QA-36A, 42" IH rear blade, 42" IH landscape rake, #1 tiller, #40 box blade, 59M shredder, #2 cart, International 3312 push mower, International 250 power washer, 1952 IH refridgerator, 1971 IH 1210 3/4T 4x4 truck ![]() ![]() ![]() |
According to parts tree, the bolt is a 1/2-20x1.5" long. Is the bolt you have long enough?
1989 - Cub Cadet 1772 1987 - Cub Cadet 1572 w/Rear PTO & Cat. 0 38" Lawn Sweeper #196483 42" L42 (Bush Hog) Rotary Cutter # 190349 45" 2-Stage Snowblower # 196364 48" Haban Rotortiller Rear PTO Driven #190356 54" SnowBlade with hydraulic Angle #196376 60" Haban Mowing Deck #196374 |
I discovered the hole in the bracket is only threaded part of the way. I cleaned the threads with a tap but still wasn't happy with the way the new bolt fit. The hole is almost 1 1/2" deep, but the threads only went in about 3/4". By running the tap all the way to the bottom of the hole I was able to put a longer bolt in as suggested and get it pulled down tight. Looks like this just might work.
2082 w/60" Haban Deck & 450 Blower,AGs,weights 2084 w/54" Deck & 451 Blower 2086 w/54" Deck, 54" Haban Snow Blade 1864 w/54" Deck and weights 1641 w/48" Deck 1650 w/44" Deck parts Tractor (getting smaller all the time) 445 John Deere w/ model 40 FEL (went over to the dark side) |
Glad to hear you got that taken care of!
![]() Your Pops is going to have a great tractor!
Travis 1993 Cub Cadet 2064 1988 Cub Cadet 2072 1980 IH Cub Cadet 782 w/CH20 1966 IH Cub Cadet 102 w/K301 1961 IH Cub Cadet O 1967 IH Cub Cadet 102 & 122 ![]() ![]() ![]() ![]() JD 2155 w/ 175 loader |
Yes the bolt that came out and the one I tried first was x 1/2" 20 x 1 1/2" , after running the tap all the way to the bottom of the hole I was able to use a 2" bolt.
