Old 12-23-2014, 10:27 AM
Group_44's Avatar
Group_44 Group_44 is offline
I'm a little confused about what I am seeing in the photos showing the tensioning spring. I have a 450 and a 451 blower and neither of them have that round rod with the spring attached, are you sure it is a 450/451 blower? It looks more like a 551 as far as the tensioning system and the lower carriage goes. Here is what the 450 currently attached to my 2082 looks like. Also the pulley that you didn't change, the rusty one, looks like it is on an angle. Maybe the bearing or mount pin is worn. Are you mixing parts between a 451 and a 551?
2082 w/60" Haban Deck & 450 Blower,AGs,weights
2084 w/54" Deck & 451 Blower
2086 w/54" Deck, 54" Haban Snow Blade
1864 w/54" Deck and weights
1641 w/48" Deck
1650 w/44" Deck parts Tractor (getting smaller all the time)
445 John Deere w/ model 40 FEL (went over to the dark side)
Old 12-26-2014, 11:07 PM
johnpded johnpded is offline
No the belt is right side up. But I discovered that one of the augers has a broken shear pin. I don't know if that makes a difference in the balance and that causes it to come off. I heard that not running a cub cadet belt would make it jump off but I don't know if that is true
Old 12-26-2014, 11:16 PM
Well I'm not sure about mixing the parts. The tension rod was on it when I bought it. The rusty pulley spins fine and even. I'm stumped
Old 12-27-2014, 12:05 AM
Ok, that isn't a 450/1 it's a 551. Lower frames are different on the 551. What is the SN# of your tractor? The early SN#'s call for the 450 blower and the late for the 451/551. You may have the wrong PTO for the particular blower you are using which would throw off belt alignment.
Grasping straws here.....
No, the sheared pin will not make the belt go funky. Not related at all.
Old 12-27-2014, 04:46 PM
Group_44's Avatar
Yep, that's what I said.
1641 w/48" Deck
Old 12-27-2014, 08:54 PM
Yup its a 551. 2 of the upper mounting pivot bolts seem loose which I can move the bower forward and back but I don't think that is it either. One of the shoulder bolts where the blower slides over when you mount it is tightened more than the other. I'm thinking the blower mount isn't back far enough. I'll try that tomorrow. What's your thoughts on not using cub cadet belts?
Old 12-27-2014, 09:15 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
If you are messing up the correct, big $ cub belts as it is. I would use cheaper belts until you get it figured out. Just my
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 12-27-2014, 10:32 PM
No just the mtd belts right now
Old 12-28-2014, 07:11 AM
Yup its a 551.
Look at all postings (15) it took to get the right model number of the implement.
This is why it is important to give complete and accurate information from the original post.
Old 12-28-2014, 10:58 AM
Buy a blade. Those do not throw belts.
Seriously though, I have no idea why the blower is throwing belts. Good luck.
