Old 12-23-2014, 09:16 AM
Steve149's Avatar
Steve149 Steve149 is offline
I wonder what my 15 year old 57' x 45' shop would cost today??
All "I" beam construction,,,,,,
The roll-up door is 18' wide. for scale
I have a couple beam clamps, but, have not used them much, because of the loader,,,
I used the beam clamps when I built the building to move the beams.
I got a trolley too, but, again, I have found zero need for it,,,,,, in 15 years.
An engine hoist might be a better, safer and more convenient option??
That "beam" is hard to move!!
CAD I agree the beam is hard to move...everytime I do something where it is at I have to move it LOL!!!! The engine hoist is a good option but it is just something setting around that ol clumsy here can trip over! I think the beam I have, after looking up the specs on that page Jon posted, will be adequate for this cause it measures out to those specs. Actually think that is the reason I got it in the first Place...omg memory loss isn't it great???
Old 12-23-2014, 10:21 AM
Typically, the beam will not be the issue, what is supporting it and stabilizing the beam is more of a concern.
Then there is the connections,,,,,, who is doing the welding??
Old 12-23-2014, 10:29 AM
Steve149's Avatar
My thought was to use 5" Sch. 80 pipe, which I have, and weld plates top and bottom. The bottom will be anchored to the concrete floor, and there will be 2 outriggers welded to the pipe and also bolted to the floor for lateral stability. As far as the welding goes that will be me and Mr. Lincoln!
Old 12-23-2014, 10:55 AM
Steve149's Avatar
It would something similar to this setup only heavier center support and no wheels.
Old 12-24-2014, 01:15 PM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
I would incorporate the vertical supports into the wall assembly.
You might want to go a step further and install two jib cranes inline with each other when the beams are lined up.
A buddy of mine did this and can transfer/ run the trolley from one jib to the other jib.
With two jibs on opposite sides he has great coverage of the shop floor.
I doubt what he did would pass an OSHA inspection but it does work excellent.
