Old 12-30-2014, 08:21 PM
Bugjunkie66's Avatar
Bugjunkie66 Bugjunkie66 is offline
You should definately get it if you want to use it. I have a tiller on my 149 and it works great. I have a 2800 sq/ft back yard garden that I feed my family with and I couldn't do it without this machine.
I got it about two years ago and the first time out it broke a chain. I tore it down and completely rebuilt it and it's been a work horse ever since. I got the replacement chain from TSC and new bearings from an internet bearing distributor. There is a big gasket that goes around the entire drive housing, you can just make one with gasket material from Grainger.
Make sure you take lots of pictures of the entire dissasembly process so you have reference for re-assembly.
PM me if you have any questions and good luck, spring is just around the corner!
Steve
149 with #2A Tiller
169 mowing machine
1864 with 3pt hitch & 54" GT deck
Haban Sickle Bar
DB moldboard plow
Brinly #10 plow
1959 DB Suburban with 3pt
882D with 3pt and front remotes - "in progress"
Old 12-30-2014, 08:32 PM
Looks like we are into re-build the tiller season.
http://www.onlycubcadets.net/forum/s...ad.php?t=36411
http://www.onlycubcadets.net/forum/s...ad.php?t=36378
Old 02-04-2015, 11:23 PM
Going Sunday after church to fetch this #2 tiller, I'm told it turns but is loose and needs bearings. Mule drive, box and tiller included. 100 mile round trip to the next county. Pics late Sunday!
Old 02-04-2015, 11:35 PM
Bob95065 Bob95065 is offline
Originally Posted by Rmowl View Post
I use a no. 2 tiller behind a 782 and it's awesome. Highly recommend getting one. The belt was around $100 from the dealer, got one for $30 from vbelts4less.com. I'd scarf it up if price is right. Put some hours on mine and never had any belt issues, even in really hard ground
Would you mind posting the part # belt you bought?
Old 02-08-2015, 06:58 PM
Mgauthier Mgauthier is offline
Can someone tell me what model this tiller is? Also will it fit on my 1450.
http://providence.craigslist.org/grd/4833579878.html
Old 02-08-2015, 07:32 PM
Looks like a #2. If it is I have a #2 behind my 1450. Do you have a 3 point hitch? You'll need one to use a tiller.
Old 02-08-2015, 08:58 PM
Nope I guess I will need to get one. I thought I saw a vender on this site that was selling them but I can't seem to find them now.
Thank you for the quick reply.
Old 02-08-2015, 09:33 PM
You may be thinking of a "Sleeve Hitch Adapter" a three point hitch is what a Sleeve Hitch Adapter hooks to. A tiller fastens to a three point hitch without a Sleeve Hitch Adapter.
This might answer some questions for you, if you already knew these things, disregard this post.
http://www.onlycubcadets.net/forum/showthread.php?t=4
Old 02-08-2015, 09:45 PM
I thought the tiller mounted to the 90 degree pulley and the pulley mounted to the rear end. Then you would lift it with the pin in the hitch? My cub has a hitch in the back.
Old 02-08-2015, 09:49 PM
If you have a NF, these are the pieces you need ( WF rear lift similar )
click for larger pic
Starting on the left, you have the rear lift, the tiller gear box mount and the tiller itself.
