Old 12-30-2014, 08:28 PM
chris hall's Avatar
chris hall chris hall is offline
i have been reading up on the repair manual. i have almost talked myself into taking a stab at it. i may need to ask some questions thou. thanks guys for the input so far.
105(sold)782x3 &124(sold) . Lawn sweeper yard cart. Homemade 3 point hitch narrow frame sleeve hitch spring assist ih snowplows . Rear weight bracket and suitcase weights.Lots of extra parts 😀.
Old 12-30-2014, 08:39 PM
Chris
I've been inside 3 or 4 of them in the last year. The first one I figured this is going to be a major project, not so bad next one it was OK the first one didn't blowup or leak, by the third it's these are no big deal. Just take your time, read the manual and make sure everything is kept CLEAN and you should be just fine. If you have a question holler and we'll do our best to help. If I can do it so can you.
Old 12-30-2014, 09:16 PM
ford4150's Avatar
ford4150 ford4150 is offline
Check real close. I thought I had a cork gasket leak. Turned out to be the expansion plug in the transmission case.
Old 12-30-2014, 09:20 PM
sawdustdad's Avatar
Yes, Chris, with a clean work area, it's not bad. Be sure to read the dis-assembly instructions and don't mix up the parts. Some look nearly identical but aren't. Follow the reassembly instructions carefully. On one rebuild, I got the charge pump o-ring out of position, (pinched) and that disabled the entire unit. Just work slowly and methodically. I've been through 3 or 4 of them now.
Old 12-30-2014, 09:22 PM
Bob95065 Bob95065 is offline
I split my 1450 this past spring. It was the first one I split. I was surprised at how easy it was. These garden tractors are well made and pretty simple.
A NF will be a little more difficult but shouldn't be too bad. The lack of a tunnel cover will made disconnecting the driveline a little harder. It could be worse - have you ever replaced a timing belt on a v6 engine? Splitting a CC is waaaay easier.
Old 12-30-2014, 09:33 PM
Talking
First time for me was November, and it went back together in less than one beer. Drove it outta the shop when cracking the second.
Spent another Sunday afternoon adjusting the hydra...
The v6s I hated to belt the most were twin cam Maxima's.
Old 01-01-2015, 06:36 PM
chris hall's Avatar
ok guys its out !!!!!! it took about 1 1/2 hours but, i was taking my time.here's what i know so far. the check valves on top of the pump are stuck. the cork gasket was leaking .i have some major wear in the trunnion.i cant see anything leaking from the trunnion shaft seals or the seal on the back of the pump.
Old 01-26-2015, 08:39 AM
chris hall's Avatar
Talking update
the 105 is back together with no leaks. thanks guys for all the advise and answered questions.i decided to reseal the pump as well.
Old 01-26-2015, 08:50 AM
Well done!
