Old 01-01-2015, 08:49 AM
yeeter yeeter is offline
I succumbed to just taking big parts to a blaster. Little stuff I got a small benchtop cabinet for.
Even tried one of those siphons that fit onto a pressure washer. Wet sand isnt as messy, so I thought. Wrong. Its a mess.
And airborn sand particles arent good for the lungs.
The blaster charges me .. I dont know, $40 or $60 per hour, but an hour to them can make some serious progress.
+1 on the leafblower - blow my shop out regularly and beats trying to sweep it (especially the dust settled in all the crannies.
Old 01-01-2015, 07:59 PM
garnold's Avatar
garnold garnold is offline
Gene,hahahaha
You can make a small cabinet out of a plastic tote that you store stuff in.I think you saw mine?
Any chance you can post a pic and refresh my memory? I have one of those big grey totes out by the shed that I could use. Good idea.
108 upgraded to 12hp
127 with all the trimmings
73 WIP
75 WIP
Blade, blower, decks
Tons of left over parts
Old 01-01-2015, 08:02 PM
garnold's Avatar
Check out this one. Pretty nice.
http://www.ar15.com/forums/t_6_19/41...g_Cabinet.html
73 WIP
75 WIP
Old 01-01-2015, 08:32 PM
Gene,
Pretty much what I did but I did not use the top.I made one out of 3/4"plywood and made it 6" taller and put a larger piece of glass on it.
Up to 534 and counting...
Old 01-01-2015, 09:23 PM
mudpatrol1's Avatar
mudpatrol1 mudpatrol1 is offline
i saw some nice homebuilt ones on youtube,yet another project for me... i used a large stand up glass beader doing antique auto restorations,got spoiled. one thing noteworthy is the different types of media. NEVER use sand in one of these,plastic media may take a bit longer to remove rust,but there is very little dust. makes seeing what your doing way easier. as far as sandblasting goes,we had a concrete silo full of sand,i wore a protective headpiece with fresh air being pumped in. i think the blast hose was 1 1/2,running 120 psi. it would knock you down from the pressure if you wern,t careful. dont miss those hot summer days blasting a chassis with 50 plus years of rust and crud on it.
Old 04-30-2015, 01:31 PM
OldSkull's Avatar
OldSkull OldSkull is offline
Red neck one LMAO
I wish I have picture of the one I did with an horizontal 60G compressor tank. Any cabinet need to vented otherwise you see NADA, a garage vacuum cleaner is a very common mod.
Gilles.
1963 100 (red)/in storage
Old 04-30-2015, 01:54 PM
paulhentschel paulhentschel is offline
Default sand blaster
I like EricR 's idea to blast in but most days we get rain here so I built a 6x12 lean to onto my shop,with a steel bathtub for a reservoir to hold my sand and a window fan ,lights and a paint mask under the harbor freight hood.But for the larger items we have an industrial blast company nearby.
