Old 01-06-2015, 03:17 PM
Originally Posted by snoel View Post
The missing piece is called a "plow point", in my neck of the woods.
We call em plow shares in this part of the country.
I've always called them "shares" too.
They are called shares. Google it. Or try walking into a farm dealer and asking for a "plow point". They'll look at you funny and tell it's called a share.
Who knows where the "frog" is?
Old 01-06-2015, 07:06 PM
bocephus1991's Avatar
Behind the molboard isn't it?
Brian
Old 01-06-2015, 07:22 PM
Merk Merk is offline
The plow was sold thru Sears. I'm not sure who made it for Sears or this is something Sears made.
Here are few different views of that plow.
Project Uncle Dick
Cub Cadet 70
Old 01-06-2015, 08:25 PM
Looks like it should work fine! Never have seen one like that.
Brian
Old 01-06-2015, 09:01 PM
edw's Avatar
edw edw is offline
I thought I knew what the frog was but I would have been wrong.What I thought was called a frog is actually called a shin. I googled and found this site thought it was interesting so I hope the link works.One type of mouldboard it did not mention was a slatted mouldboard.
Technical Note 20. The Moldboard Plow - The Open Furrow...
open-furrow.soil.ncsu.edu/.../DHC/The%20Moldboard%20Plow.pdf
Ed Wells
Jeffersontown Ky
Old 01-06-2015, 09:26 PM
It is a good plow to plow with. Best thing I like is it doesn't plug up like some other plows do.
Project Uncle Dick
Cub Cadet 70
Old 01-07-2015, 04:45 AM
Ohiobowhunter06 Ohiobowhunter06 is offline
Merk is that your plow?? I'm gonna go to some old farms this week end an see if I can find a share that with will work on it If not looks like I'm gonna be in the market for a new plow
Old 01-07-2015, 10:46 AM
Sadly,
you are prolly not gonna find a "fitted" share too easily.
might just as well look for a complete plow, and use that one for the flower bed decoration.
FWIW:
IH plow chief did use a Spear point, it was below the shim, on the end of the share.
As it would wear, it kept a person from having to purchase a complete share.
IIRR I would replace 2 maybe 3 points before I needed to replace the share.
Still got a 3 bottom 14" plow chief behind the barn, but not going out to take a pix of it just yet. it is a bit snow covered out there.
Old 01-07-2015, 12:38 PM
If you can drill it...... just go buy a new plow share for like a 14" IH plow. They're less than $20 and most farm stores keep them.
Old 01-07-2015, 04:27 PM
That is my plow.
I would try to find a complete Brinly moldboard section (landslide-share-moldboard and possibility frog) and try to use the Sears framework.
Another possibility is to find a Sears 3 point plow and used the pieces you need.
Trying to find a point for a Sears Plow could be hard to do.
Biggest issue you will have is the front part of the landslide and share is one piece.
Good luck finding a share.
Project Uncle Dick
Cub Cadet 70
