my plan from the get go with this tractor has been FEL. found that z482 at an auction for a hundred bucks and it has that pump on it behind the injector pump so i figgered bonus. seems like a great pump for a loader to me plus you couldnt find a cleaner way to mount one
982D kwik-way loader w/3 spool control and front and rear remotes,2182, 1812 cat 0, 1440 puller, 3185 grass killer, 2x 450s, QA42, 364, tiller |
I"ve got a D600 sitting waiting for install into a gear drive. I was planning the same thing to give a GD hydraulics.
Scott Murphy did a nice one a few years ago. Google "Scott Murphy gear drive" and you will find the link. He does some very nice work.
Wasn't there a recall or at least a movement to replace that steel fan bracket with a beefier cast aluminum one? My 782D had one that I replaced when it developed cracks in much the same way yours did, and fell off. I was EXTREMELY lucky the radiator survived!
1989 - Cub Cadet 1772 1987 - Cub Cadet 1572 w/Rear PTO & Cat. 0 38" Lawn Sweeper #196483 42" L42 (Bush Hog) Rotary Cutter # 190349 45" 2-Stage Snowblower # 196364 48" Haban Rotortiller Rear PTO Driven #190356 54" SnowBlade with hydraulic Angle #196376 60" Haban Mowing Deck #196374 |
I've installed engine heaters on several Kubota engines and they've always gone in the head. The frost plug areas on the block don't have enough depth for the heating element. It's just a thin water jacket and the holes don't line up between the cylinders so the element could go in that larger area.
169, Kwik-Way loader, 1100 (going to transplant a 10 hp Kohler in it) |
Travis 1993 Cub Cadet 2064 1988 Cub Cadet 2072 1980 IH Cub Cadet 782 w/CH20 1966 IH Cub Cadet 102 w/K301 1961 IH Cub Cadet O 1967 IH Cub Cadet 102 & 122 JD 2155 w/ 175 loader |
34 degrees today plugged in for 30 minutes 15 sec on glo plugs and whoo hoo it started. normally at this temp it would need to be jump started as it dont have the starter upgrade yet. so played a little in the snow
