Old 01-18-2015, 04:28 PM
Hey!, No Problem!! I'll have to have a 3rd look at that!! But then I really needed to get at the anyhow to see about the shims.
I'll give it a try before I button it all back up just fer the heck of it!!
Meanwhile, it's back to my game of rear wheel nuts and bolts roulette!!
Helping a friend get a 104 running, his tank is a mass of varnish and rust.
Old 01-18-2015, 04:40 PM
c69ss396 c69ss396 is offline
I replaced the governor shaft on my 102 with just removing the pan, its a pain but doable. Getting it out is easy, putting putting it back is a biotch...
Old 01-18-2015, 04:47 PM
When I just did it, I just turned the motor upside down, dropped the shaft in, put the magnet through the hole and used the screwdriver to push the shaft over to the magnet. It literally took seconds to time it.
Old 01-18-2015, 07:06 PM
blee128 blee128 is offline
Ok so after messing with all day the governor has been removed from the motor it was a carb problem
Old 01-18-2015, 08:51 PM
bocephus1991's Avatar
Nobody's said anything, but that's a unique way of cleaning a gas tank! Bungy strapped to tire chains on your cub!
Brian
Old 01-18-2015, 09:40 PM
I'm kind of interested now.....
How did you mistake a carb problem for a governor problem?
Old 01-18-2015, 09:44 PM
sure would take any manual labor out of it.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 01-18-2015, 11:01 PM
That it would Tim! Jon , I would say that not everyone has the experience that you or others do on working on engines. I'm not bashing you or the op but, we've all been guilty of jumping the gun in diagnosing engine problems.
Brian
