Old 02-09-2015, 09:29 PM
bocephus1991's Avatar
Try to find a k series kohler for it or a magnum. That would be easiest to put in it.
Brian
Old 02-14-2015, 12:43 PM
bkw3614 bkw3614 is offline
Jonathan,
I am not going to spend much money on this engine. I am told that it ran when parked; although that doesn't describe how well the thing ran while parked. I am further told that the charging system didn't work properly and it would drain the battery . That was the reason it was parked. I don't know how long ago that was. The P.O. had no interest in fixing it.
A series II would be my first choice for replacement, just because it is easy out, easy in. A magnum would be the next choice.
There are a lot of tings to figure out on this tractor. At -10 degrees today, I won't be looking at it very much, but I wait for warmer days to start the project. Oh winter, why are you here every year?
Old 03-09-2015, 12:28 AM
Update on the 782.
It was 45 degrees here today, and I took out the 1250, just for some seat time.
When I returned,I looked at the 782, and just for the heck of it, I put a bar on two of the bolts connecting the driveshaft to the KT 17. IT TURNS! I didn't turn it far, maybe 1/8 to 1/4 turn on the shaft, and very slowly. There was very little pressure required on the bar to make it move. But I was pleasently surprised that the engine turns. Maybe it will actually start with a little bit of coaxing.
The hydro lever moves a little bit, the ignition switch turns as it should with a key, and the brake pedal is loose. Things could be looking up for this machine.
Old 03-09-2015, 10:10 AM
The motor is stuck to the point that it has been soaking for what, 3 months? Yet, your hoping it will start..... your hopeful. It's not gonna run bud. I suggest if you want to rebuild that engine, you don't even attempt to start it. Good way to score a cylinder and lock it back up.... if the cylinders are any good anyway. If you can get it to turn, then take it apart.... don't try starting it please.
Old 06-13-2015, 09:18 PM
Update on the 782 Problem. I got the Kt-17 Series I running, and it runs alright, not great, but alright. It doesn't charge, as the P.O. said.
Now for a few questions: First, the Wiring Harness is pretty hacked up. I can't find one, so I am going to have to make a new one. Does anyone know of a parts source for the Delco-Packard connectors found on that harness?
Second, I have found a replacement engine for the KT-17. It is a Magnum-18 out of a newer Cub Cadet. What will I have to do with this engine to make it work in the 782? This engine has an oil filter. Where/how should that be mounted? I know there needs to be a change in the wiring harness to accommodate the Mag-18. What is this change?
I do appreciate everyone's input.
Old 05-18-2016, 11:16 PM
This is a very old thread, but finally, there is an update on the 782 Problem
I am finally at a point where I can start work on my 782.
Although the KT17 Series I runs, it doesn't run well, and I don't care to mess with it. The Magnum 18 that I bought is tired, and needs a complete rebuild. My question to all of you who are familiar with these engines: "Do I need to use genuine Kohler parts, or are Stens and other aftermarket parts acceptable? Are there any parts manufacturers that are not acceptable?"
I need to try to stay within some sort of a budget on this thing, and yet, I want it to be well done.
Thank you in advance.
Old 05-19-2016, 01:02 AM
Terry C's Avatar
Terry C Terry C is offline
Mags are too expensive to rebuild. Repower with a CH or a vanguard
But it's your money do as you see fit.
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 05-24-2017, 02:18 PM
Smile Time to get this done.
After a year, in the making, a move, and doing some research for a grad school friend, I am working on the 782 again.
I think I have most of the large parts that I need. What I don't have, or what surprises that come my way, should be obtainable through want ads on this site, other sites, Craig's List, E-Bay, my local CaseIH/Cub Cadet dealer, other local sources, or with some creativity.
Awhile ago, I found a Magnum 18. A friend tore it down, bored it .010", and overhauled the engine, using a majority of genuine Kohler parts and a Kohler/Carter #26 carburetor. He spent a year on it, and did a beautiful job.
Currently, am soaking the tractor down with PB Blaster and getting my new shop ready for the task. I am finally ready to do this job.
Question: Will a sleeve hitch from a wide frame (1650) work on a spread frame (782)? I know I will have to find Frankenstein bolts.
I suppose I better take a picture of the project.
Old 05-24-2017, 02:28 PM
Hope the motor lasts.
You can get the Frankenstein bolts for JeffinPA here:
http://www.onlycubcadets.net/forum/s...ad.php?t=20875
Just send him a PM.
Old 06-11-2017, 06:28 PM
Default Tires
Working on the 782, I am trying to envision what I want for the tractor in its ending state.
I have been considering tires, and I have decided t go with a ribbed tire in the front. I think that is what it had when new.
It has 23-10.50-12 tires in the rear. I think they are a little wide for my needs, especially with my company's parade entry; as the wide tires will make loading onto the trailer difficult. Are the 13-8.50-12 tires found o some of the smaller wade-frame tractors of the same bolt pattern? It would be nice to interchange tires without much hassle.
As always, thank you for the comments.
