Old 01-25-2015, 05:23 PM
Merk Merk is offline
Originally Posted by dvogtvpe View Post
? who worries about idle? its all about WOT
I want to use the cam in a plow tractor. RPMs will vary when I plow.
Project Uncle Dick
Cub Cadet 70
Old 01-25-2015, 06:19 PM
Wbrech Wbrech is offline
That was a good looking pull austin8214. What rpm's was it turning and are you running a stock 26 carb? That's one thing the rules state is I have to run a stock carb so I'm wondering if the cam will let me move enough air with stock valves to run a 30 carb below 4000 on a 12hp.
Old 01-25-2015, 06:28 PM
austin8214's Avatar
Merk for plowing I'd suggest the Kerber gov #1 cam. It's a regrind cam and is less aggressive and cheaper than the weld up gov #3 cam. His gov #1 cam idels very well. I have a friend of mine that has one in a 10 HP puller.
Old 01-25-2015, 06:43 PM
austin8214's Avatar
He was turning about 4,600 in the video. That is a k321 running a #30 carb. In my opinion you are probably going to be better off running a #26 on a k301.
Old 01-25-2015, 06:58 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
austin8214 is spot on with his recommendations.
a 26 would be a better choice. you would lose torque by going with a 30. the next time I dyno a 14 or 16 I'm planning on putting a 26 on it to test. just for shits and giggles
Old 01-25-2015, 07:21 PM
I was planing on a 26. The one I have is going to need some attention,throttle shafts so worn that it was running pretty lean. I get this thing together and I need to find a dyno locally to set it up, that and I'm curious as to what kind of torque it's going to produce. Anyone ever drill the base of the carb for a vacum port to set the carb or am I thinking v8 again? Also I read somewhere about drilling the weights of the governor to make them more resposive? The governor makes sence to me but don't know if there is any "tweeking" to be done there.
Old 01-26-2015, 08:40 AM
mickb72 mickb72 is offline
Default cub
Hi Don, i'll be waiting to see the results of your dyno test. I have a gov 16 with a 18hp cam that i was running a small stock 30 on. I now have bored the 30 to 1" and also bored a 26 to 7/8". I would like to know which one will perform better. What to expect. Thanks Mike
Old 01-26-2015, 03:10 PM
austin8214's Avatar
Don, I found this interesting. Scroll down to where it says governor carbs. http://www.lakotaracing.com/carburetors.htm
Old 01-26-2015, 05:35 PM
dvogtvpe's Avatar
you'll be waiting a while, I don't build to any stockers
Old 01-26-2015, 05:38 PM
dvogtvpe's Avatar
I know on a 14 the torque is better with a 15/16 venturi over a 1 in. I've always felt that stockers needed smaller carbs but I've not done allot of testing on it. the smaller carb is better for torque at the low rpm.
