Old 01-29-2015, 02:56 PM
samiam44 samiam44 is offline
The kohler measuring point on the piston- is it the biggest point? could be that kohler is having you measure where it is a long flat section and giving a big # which equates to a decent clearance.
I would guess the aftermarket piston alloy is different- stay to the top half of the scale. I try for center.
Mahle piston is hyperutectic and has a lower expansion without a metal ring cast in it. *my guess*.
Old 01-29-2015, 07:45 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
they are checked at the tightest spot. all pistons are "cam ground" or slightly oval. most all cast pistons these days are hypereutectic , I referenced silicon content figuring most never heard of hypereutectic. another thing to keep in mind is fear of a cold stick. that heavy cast iron block don't expend near as fast as the aluminum piston
Old 05-15-2024, 08:21 PM
JimC1 JimC1 is offline
This is an old post, but there are a lot of assumptions being made here. Since the measurement is taken just below the oil ring on the old style piston, it makes Kohlers piston clearance seem large at .007+. When you measure an old style Kohler piston just below the oil ring, that area is not the largest diameter of the piston. The largest diameter of the piston is at the bottom of the piston. The pistons are cam ground (oval), and tapered from top to bottom. If you have .007 clearance just below the oil ring, you will have .002-.003 clearance at the bottom of the skirt. This is where the machine shop screw ups happen if the machinist sets Kohlers recommended clearance at the bottom of the skirt instead of just below the oil ring. If the piston clearance is .007-.010 at the bottom of the skirt, new ring gaps will be large and there will be piston slap. I've read about people running into this problem. Why Kohler decided to instruct people to set the clearance just below the oil ring is beyond me. It's made for a bit of confusion and overbored blocks over the years. I measured the piston clearance on an NOS K301 and an NOS K321 mini block. At the bottom of the piston skirt, the clearance on the K301 was .003 and on the K321 a tight .002. The compression and oil ring gaps were .012-.015 which is what I would expect.
