Old 01-30-2015, 11:36 AM
remove the spark plug and blow a little air in the hole.Put your hand by the muffler,if you feel air it is open,rotate the motor until you don't feel it anymore ,if you still do it is stuck open.
That's a good test, Lew. I do that all the time.
Check for air movement out the carb too though, since we think it's an intake valve.
Old 01-30-2015, 11:45 AM
CubCadet129 CubCadet129 is offline
Smile
Or not seating good. This also applies for intake and can be tested with a leak down tester,a blow gun that has a tip that seals the plugs diameter, or the quarters inch quick connecter found on some compression adapters like the one I have if the coupler is the same size and type.
Old 01-31-2015, 04:25 PM
billdunn64 billdunn64 is offline
I pulled the valve cover off this afternoon. It appears that both valves are going up and down. I pulled the spark plug and I feel air coming out of the spark plug hole when I crank the engine.
Old 01-31-2015, 04:42 PM
I moved this to the Kohler section for you. Time for the Kohler masters to do what they do best.
Old 01-31-2015, 05:56 PM
The valves going up and down doesn't mean that they are seating. Did you adjust them while you were in there? Do you still have the cover off?
Time to pull the head, like I suggested in post #6.
Old 01-31-2015, 07:17 PM
that is my plan for tomorrow I pulled the plug and it was carboned up pretty bad and it was also the wrong plug
Old 02-01-2015, 11:03 AM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
faulty ignition components can give you the effect that timing is off while it is set correctly.
Old 02-01-2015, 06:48 PM
what plug was in it? it should be a champion H10c if your 125 has its correct 12hp kohler k301
Old 02-01-2015, 07:42 PM
it had a J8C champion that is what was in it when i got the cub.
Old 02-01-2015, 08:00 PM
Should have been fine. Near as I can tell the only difference is the reach. Heat is similar. It wasn't your problem, unless it was bad.
