Old 02-01-2015, 09:35 PM
Originally Posted by RedHawCadet View Post
I measured 7" and the length of the carriage is 31 3/8's
That should be close enough. Pull that cross pin and it should fit.
Old 02-01-2015, 09:38 PM
Your subframe is for a 70 thru 123.
Old 02-01-2015, 10:25 PM
RedHawCadet RedHawCadet is offline
So what does the 72-147 frame look like?
Mark
1971 Model 73 - Hydraulic lift,Fenders,Creeper,Lights,Sleeve hitch and Weights
1967 Model 102- mower
1965 model 70 - weights,rear lift and spring assist
Model 100 resto mod project, rear PTO, hydraulic lift
QA42 snow thrower
42in front blade
Grandpa's F-12 and Super M
Old 02-01-2015, 10:38 PM
See post #4
Old 02-01-2015, 10:45 PM
I don't have any measurements and I don't keep them in my head, but I'm thinkin Jeff is right, pull that cross bar out of there and see if the holes will line up with the holes in the frame.
Old 02-01-2015, 10:54 PM
If it does not have the extensions on it (I cannot tell from the picture) then it will not work. I had one and it was close but did not work, despite my best explicatives!!
Old 02-02-2015, 03:38 AM
Well then if the only differences are the front mounts. Could anyone give me the dimensions and I'll make new ones. Thanks for the help
Mark
QA42 snow thrower
42in front blade
Old 02-02-2015, 08:30 AM
mmzullo mmzullo is offline
You can use a front mower deck mule drive from a bolt on sub frame and remove the 4 inch flat brackets and mount the blade to that. It's much stronger.
Download the 42 spring trip blade 1 manual. In illustration 5 there is a picture of what I was talking about.
Also I noticed that have instruction for a bolt on sub frame mounting instruction of how to mount it to an Original. Illustration 3.
Old 02-02-2015, 04:31 PM
I'm sorry iv looked at the manual and just dont understand what 4" brackets to cut. I do have a mule drive off of a 122 to use.
Mark
QA42 snow thrower
42in front blade
Old 02-02-2015, 06:06 PM
here are some pics of the brackets.
