Old 02-02-2015, 05:10 PM
Originally Posted by Tankman View Post
67 year old newbie here. What's the difference 'tween a 1641 garden tractor and a super garden tractor?
Longer, larger wheels and tires, bigger front axle, power steering, turning brakes and lower gearing. Rear PTO was also an option with a Cat 3 point hitch. Power wise they used 18 -22 HP engines from Onan, Kohler, Kubota and Kawaski. This is the list of Supers.
982 Onan
984 Onan
986 Onan
1572 Kubota D 600 diesel
1772 Kubota D 640 diesel
1872 Kohler Mag18
1912 Onan
1914 Onan
2072 Onan (early 2072's had Onan's)
2072 Kohler Mag 20
Cyclops
1782 Kubota D 640 diesel
1882 Kohler Mag18
2086 Kawasaki FD620D
2082 Kohler Mag 20
2182 Kubota WG-600 gas
2084 Kohler CH20
2284 Kohler CH22
Old 02-02-2015, 05:14 PM
Originally Posted by dragoncub View Post
Just picked up 1872 with a 60" deck and a three point and a rear pto. It's alittle rough but should have it running in a few days. Ohh and I'm going back in a couple weeks to get the tiller for it.
Congrats on the 1872. Rear PTO is hard to come by.
Old 02-02-2015, 06:20 PM
What they said.!!!
Up to 534 and counting...
Old 02-03-2015, 01:03 AM
red56turbo's Avatar
DragonCub,
Nice snag my friend! Three point and rear PTO to boot. Cool! Don't delay on the tiller. They are harder to find and pricey. Snap some pics of it after ya pick it up.
Josh
Diesel Cub Cadets...........
Old 02-08-2015, 11:12 AM
dragoncub dragoncub is offline
Yesterday I got a chance to mess with it. I have a bad pto switch so I had to bypass it to get it to turn over. The carb was no good so I pulled the carb off my 782 and it fired right up runs good but have an issue. The front seal on the hydro pump leaks. Guess I'll pull all that apart and see about getting a new seal Monday.
Old 06-04-2015, 06:19 PM
Well it's been awhile but I got it running and mowing. I had to get a new ignition switch, replace the seal on the hydro pump and while it was apart I noticed the bushings on the drive shaft were destroyed so I ordered some new ones and installed them. Since then I have mowed with it several times I have to say out of all the mowers I've owed this 60" haban deck is the best mowing deck I've mowed with. Now I'm going to start fixing the worn out parts, deck bearings, tie rod ends things like that. Also the PO put a tube in one of the front wheels and it rusted it pretty good so I'll have to cut out the bad spots and repair it with one of the old rims I've got.
Old 06-04-2015, 06:24 PM
