Old 02-10-2015, 12:52 PM
Steve149's Avatar
Steve149 Steve149 is offline
In the first picture on the grill is that a decal or an emblem that is supposed to go there? I have a 149 also and mine is bare...
PS... nice looking 149!!!
Old 02-10-2015, 01:01 PM
All the 1x8/9 series should have that decal on the grille.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 02-10-2015, 01:04 PM
Steve149's Avatar
Could hardly see it in the photo Tim do you happen to have a pic of it ?
THanks
Old 02-10-2015, 01:54 PM
PaulF PaulF is offline
Very nice original looking 149, those rear ag tires set it off nicely.
If you've never used it before, you're going to appreciate that hydraulic lift. It should make using the pushblade much more enjoyable than the armstrong setup on the Suburban.
Paul F
Infantry Veteran
Original...100/123/147 custom...149 FEL...782D...1282...1864...2182G
Old 02-10-2015, 05:39 PM
zimm17's Avatar
zimm17 zimm17 is offline
I spent a few minutes going over the whole tractor today. I'm definitely going to repaint the white stuff. It's not original paint, it's been spray paint touched up over the years. So that and decals should help. I need to find out how to get the dash off, decals are good, but there's white overspray on the wrinkle black, I can reshoot that.
1973 Cub Cadet 149
2023 John Deere X590
Farmall B sitting in relative's barn
Old 02-10-2015, 06:25 PM
Trekrider60's Avatar
Trekrider60 Trekrider60 is offline
Hi Zimm17 and welcome to OCC. I'm sure you will love your 149. To get the dash tin off I removed the amp gauge, choke and throttle levers, hydro lever, steering wheel, and the steering column. I was doing a complete refurbishing so all of it came off. I followed IHinIN's process in his work on his 129 cleaning up the bright areas, taping off and respraying the black, and adding new decals. Good luck on your work.
Gene
149 w/Front Blade
Old 02-12-2015, 10:15 AM
zimm17's Avatar
Does anyone have original pictures of a 149 or similar tractor? I'm curious to see what parts where painted what color. I'm assuming the engine was yellow, but I see lots of colder cubs with black engines, or yellow starter/generators while mine is black. Also the seat spring/mounts on mine are white, not sure if that's correct or not.
My brother has a HVLP spray gun and I'm going to buy white and yellow from the case/IH dealer this weekend.
I'm undecided if I want to just paint the white tins ASAP, or wait a month for snow season to be over and partially strip the tractor down (pull the fenders and tin work) to degrease the tractor, and maybe paint the outside of the frame and do the fenders in yellow as well as the white tins.
I also need to figure out if I want to repaint the wheels when I swap tires this weekend. I think they'll clean up pretty good, but I don't want to regret how they look after the new tires are on.
Here you can see that I what to do the white areas. Not sure if I want to keep the original decal on the tunnel or use the new one.
You can see the fenders have been touched up over the years.
1973 Cub Cadet 149
Old 02-12-2015, 12:10 PM
Since your spraying with a gun I'd look into the case/IH paint, I use it on my tractors and it sprays nice and has a real nice shine to it.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 02-12-2015, 12:19 PM
zimm17's Avatar
I am going to pick up case/IH paint, a quart of each. Do you use their hardener and reducer, or buy something else?
1973 Cub Cadet 149
Old 02-12-2015, 12:24 PM
I use there hardner and reducer. If your planning to paint the yellow you will need more than a qt, yellow( regardless of the brand ) doesn't cover very well so it will take more coats. I useds about 3 qts doing all the yellow on my 108, I bought a gallon and had about a qt left over.
Pap's 100
Restored 108
1211 Dual Stick
1050
