Old 02-16-2015, 01:31 PM
twoton twoton is offline
I’m guessing that simply replacing the friction disc may not be considered a thorough job. Truing up or dressing the corresponding surfaces on the clutch and or pressure plates would also be in order would be my guess. Would anyone be able to provide me with what might be considered “ out of service” dimensions for the thickness of the two items that might need to be chucked in the lathe?
Old 02-16-2015, 01:36 PM
So it looks like this is where I am currently at in the parts department:
New rag joint
New ball bushing for transmission input yoke
New friction disc
And as far as my trip to see my good friends at the machine shop;
Turn the pressure plates
Anything else?...
Old 02-16-2015, 01:37 PM
Oh, sorry, wrong picture.
Old 02-16-2015, 01:40 PM
Here is a link to the clutch from Part Tree.
http://www.partstree.com/parts/?lc=c...&dn=0017500012
Old 02-16-2015, 01:48 PM
I truly appreciate your quick response Mr Sam Mac. And what a reasonable cost of just $50.26! I'm thinking that while I have this all apart, I may consider replacing the through out bearing in the process. I did see in the owners manual that some of the drive shafts had a grease fitting. Does anyone know if that is for the throughout bearing?
Old 02-16-2015, 01:51 PM
I can't say for sure, I've never owned a 1200. I'm sending you a PM for a place with better pricing than Parts Tree.
Old 02-16-2015, 01:52 PM
Did I say throwout bearing?
Heading out to shovel out the mother inlaw, check back in latter, Thanks!
Old 02-16-2015, 02:10 PM
Some good reading for you.
Service manual
http://www.onlycubcadets.net/forum/s...ead.php?t=4644
Clutch rebuild how to
http://www.onlycubcadets.net/forum/s...ad.php?t=33653
Old 02-16-2015, 02:38 PM
While you are into it, inspect the 3 pin clutch driver for cracks.
This is what is bolted to the end of the crank w/4 short 1/4" bolts.
They are still available but NOT CHEAP!
If it badly cracked, it will likely soon fail.
You only want to do this once so do it right.
Good luck!
Old 02-16-2015, 05:03 PM
Will do Mr finsruskw, I'll go out and check it out right now.
Tags
clutch, cub cadet 1200 quietline, rag joint
