Old 02-28-2015, 09:55 AM
garth68 garth68 is offline
I would restore it, and on a side note, it always amazes me how much better the old goodyear tires hold up over the new crap they put on lawn equipment.
Old 02-28-2015, 10:13 AM
raytasch raytasch is offline
Thanks for the feedback and comments, guys.....and girls if there are any on here.
The caster is off due to a cracked hub, another reason the tractor was retired. I've toyed with the idea of replacing the hub but still open on that decision. I'll probably replace both of the wheels.
I believe those tires were original when I bought the tractor and I've not put new tires on it. They all are badly cracked outside and run tubes now. The tractor has never been left out, exposed to the elements.
Yes, the seat appears to be IH Cub original as far as I know. That cover is at least 42 years old, on the tractor when I bought it and showed signs of being used at that time. It is removable. All this is why I thought perhaps it was a Cub accessory. Probably not. The cover is beyond salvage now, anyway, extremely brittle.
The deck is quite solid. I've had to stop a couple cracks over the years but it is still in amazing condition, main spindle excluded. Main spindle on my "to do" list.
Question: Anyone have any experience tightening up the spindles, kingpins? These are worn. I've not determined if the wear is in the axle or the vertical spindle section, itself. Front end slop is the biggest issue with the tractor.
A bit more information on the Cub.
The engine was rebuilt several years and several hundred hours back. The PTO clutch was rebuilt and the drive clutch rebuilt at the same time.
