The spec # matches as a Mag 18 Only if you have deep pockets (you can replace it for the same price) and know a shop that can sleeve. Pretty limited as far as piston sizes and internal parts availability. |
J-Mech,
Thank you for the explanation. I should be able to get to my spare engines this weekend. I have two M15's and a M18. I know the spec numbers on the engines are the same. I will try to take some pics of the carbs and see if I can pull the numbers off of the carb. You mentioned the M15 may have a WOT limiter. Would this be external to the engine limiting the amount the carb throttle could be opened or would this be something internal? Chris |
Should be external. I noticed in the parts book that for some reason it states different part numbers for the governor control rod between the two engines. May be just a minor difference/change and totally irrelevant, but the limiter may be in the linkage.
I just looked at the tag on my 1535 engine. Says it's M 18S and spec # is same as yours, 24647. |
Thank you for checking the numbers on your M18S.
So, by what method is the engine de-rated to 15 horse. |
Marketing?
Unless I missed something, this page says the carbs and all important internal parts along with governor linkage is the same between the 186X engines and the 153X engines. Along with other applications.
http://www.partstree.com/parts/cub-c...59/carburetor/ |
This is from Small engine warehouse
" Repower old Equipment Cub Cadet 1541 Category Available replacement parts listed below, please click product number to view more information about each replacement part. Original Model: Kohler Magnum M18 24646 This was an 18hp engine that Cub Cadet labeled a 15hp.
Kohler parts list says the m 18s spec 24646 and 24647 used the same carb kit with either a 52-053-50 or 52-053-66 carburetor.
The engine I pulled out of the 1541 has an M18s spec tag but the tin says Magnum 15
Cub Cadet 1811 undergoing restoration Cub Cadet 1862 waiting for paint Cub Cadet 1050 finally got all the parts bought so next in line behind the 1811 for restoration Allis Chalmers 416 Massey Ferguson MF-8 Brinly 10"plow Soil Mover garden tractor dirt scraper Taking donations for a new bigger garage to hold them all
