I built a cat 0 for my 682 and this is what I ended up with. I started with several dimensions that Bill has posted.
The od of my frame is 10.875" wide, I didn't want to "plate" over the whole rear end so used 2"x2"x.25" angle on the sides. I have aluminum trans axle so used all existing bolt holes in the frame for mounting. If you want more info on this I could provided some dimensions that I used but I don't really have a final drawing due to the fact there was so much experimentation involved for me to get it right, well close, I still might change things. The biggest issue I have with the whole set up the way it turned out is the lift range is lower than I would like, hope to remedy that this spring summer. Good Luck! Vic |
Thanks for all the help this is gonna be pretty fun im probably gonna go cat 0 so i can mount a self powered tiller on the back ive looked for an ih tiller but no luck anywhere near me lol
Looks great Vic! I know all too well about the experimentation, still a few things I want to tweak on mine. Jhuston, keep us posted on your progress!
Bill |
Looks good Vic! I need to build the lower lift arms and the peice that connects them to the upper lit arms. The PO of my 1211 kept those parts and the top link!
Brian April 1979 1200 Quietline 44A deck 1988 1211 customized into a 1288 with a K301AQS 38C deck and a 1864 54” deck . Snow blades 42" and 54" . Brinly disk, brinly plow a cultivator and a $5 brinly yard rake! ![]() |
![]() Quote:
http://www.onlycubcadets.net/forum/s...90&postcount=1 |
![]() Quote:
