Old 03-28-2015, 02:48 AM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
I forgot to ask about the air filter, but assume it's good.
I want to say EGR valve hung open, but that isn't relevant if we're comparing it to a cub. Neither would the cat.
Fuel pressure, volume, and quality good?
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 03-28-2015, 02:52 AM
cubby102's Avatar
cubby102 cubby102 is offline
Valves ok?
Old 03-28-2015, 03:04 AM
cubby102's Avatar
Are injectors firing ok and not allowing more then they should through?....now you got me wanting to go work on a car :/
Old 03-28-2015, 08:23 AM
j4c11's Avatar
j4c11 j4c11 is offline
In my very non-professional opinion it is a timing issue. If the intake valve closes early, it will not get enough air but the same amount of fuel resulting in rich mixture and the other symptoms.
Glad I could be of help
Old 03-28-2015, 08:37 AM
seawood seawood is offline
DOHC new timing cover gasket was the exhast can out of time replaced head on a 1995 several tries to get timing right. Looked good till rotated over then exhaust cam off
Old 03-28-2015, 09:23 AM
gt383mag's Avatar
gt383mag gt383mag is offline
its a 2.4 gm nuff said... where is the fuel pressure regulator? on the rail that burnt? but wait you said injectors are not over fueling... my gut keeps thinking cam timing is off
DOHC ----
thinking #225 comp WTF? cam or cams timed wrong to each other and or to crank---- low vacuum/rich mix
I'd be looking @ alignment marks on sprockets.
And when we figger out what is wrong, we want paid Ha,LOL!
Old 03-28-2015, 09:44 AM
tech1979 tech1979 is offline
J - mech the car I had was running exactly how you describe. Fuel trims we're rich, random misfires, but 1 cylinder missed more, IAC and map readings were the same. I couldn't hear a vacuum leak. To be honest when I pulled the car in my immediate thought was the timing was off, exhaust had that wonderful sound. If your car is misfiring on one cylinder more than the other put a fuel source underneath that cylinders intake runner, I would bet money the engine speed picks up. We use a propane torch with hose.
Old 03-28-2015, 09:55 AM
jimbob200521's Avatar
Had plenty of time and cars with this engine (unfortunately). My instincts tell me timing, although the compression numbers make me wonder
-Ryan
Old 03-28-2015, 10:19 AM
Tacosteelersman's Avatar
Tacosteelersman Tacosteelersman is offline
Unmetered air comming in after the MAF, like a split in the air induction tube?
3 original cubs
1512 diesel
Ingersoll 3012
John deere 855
