Thanks Guys! are the ignition and PTO Sw the same? What is the rev relay and the rev 6w, do I need these?
The ignition switch on a 782 and the 680 are probably the same. I imagine the PTO switch would be, too. You won't have (or need) the reverse relay or reverse switch, as those came later on.
I'm interested in that wire harness for the 1210 how can I get in touch with you?
The 1210 is a mag harness, Starter location and so forth may be a little off but the harness is complete and will suit your set up, may need to reroute a wire or two but.... murphycc@yahoo.com Just pay shipping and it's yours...with ign switch. Scott |
Murphycc, thanks for the harness! It looks pretty straight forward but I have a couple ? The wiring diagram I got from R Bedell shows letters at the terminals but none of my parts have these letters on them so i'm sure how to check it. I'm not sure about the wiring by the fuses, I have two red or orange wires and a doubled up white and a single white and then two yellow that I think are the hr clock. By the motor there is a three prong plug,I only have one wire off the ign module so i'm not sure about this. Would anyone have a diagram that shows the harness as it really is and what parts they go to?
I hope I'm making sense, please bear with me. |
Scott |
BTW Dan, if it were me I would do two things-
I would first take the bundle out of the loom and after I got the harness figured out I would take it back off the tractor and wrap it up real nice with tape, much cleaner look and better protected in my opinion. Secondly, I would connect all the wires that are obvious, that should be about 80% of them, once that is accomplished it's much easier for me to concentrate on the 20% that need to be figured out. Scott |
