Old 04-02-2015, 02:12 PM
Originally Posted by mferris72 View Post
New blocks on E-Bay are usually about $150
They don't make new blocks anymore.....??? You mean used?
Blocks are the same yes..... but crank, rod, jugs are different. Same bore, different stroke. You can't just switch jugs and have a 20. It would kill it as it wouldn't have enough stroke and lose all compression.
Old 04-03-2015, 10:37 AM
dsmith30 dsmith30 is offline
So if I find a used block m18 or m20 and use all my parts from my old motor I should be good ?
Old 04-03-2015, 10:59 AM
It needs to be a motor from a CCC. Crankshaft size varied between different tractor makes. For example: Deere cranks on the PTO end were longer and larger diameter. The M18 and M20 used different carbs. So.... you really need a complete motor. A CH Kohler or a Vanguard will also work with some minor modifications to the engine mounting plate. PTO off the M may not be a direct bolt on to the Vanguard but I believe it would fit the CH.
Old 04-03-2015, 01:00 PM
Leadslingingdaddy's Avatar
There is a "new" M20 on Epay...Will have to look up the Spec number to see what crank it has...
I would go the repower route....I have a CH20 sitting on the shelf just waiting for the M18 to go in my Super....
