Old 04-03-2015, 05:23 PM
Imaddy Imaddy is offline
I changed the oil filter and oil, hydraulic filter and fluid, fuel filters and replaced the fuel with new. Bleed the fuel lines as already mentioned and installed a new battery. I've doubled up the battery to increase the AMPs as it was struggling on a single battery,
Old 04-03-2015, 05:58 PM
CubDieselFan's Avatar
When you bleed the lines, did you crack the lines at the injectors and did you get fuel there?
Old 04-03-2015, 06:01 PM
Yes, I did that. It bubbled air initially then ran with clear fuel.
Old 04-03-2015, 06:04 PM
OK. You didn't do any rewiring, but did you unhook anything? Really odd that it did crank fine before, but not now.
What about the hydrostat. Did you do anything to it, or the driveline? How about PTO? Belts, water pump..... anything that the engine runs that could cause drag on the starter?
Old 04-03-2015, 06:07 PM
no, nothing mechanical apart from fitting the axle brace kit. that all.
Old 04-03-2015, 06:15 PM
Good connections at battery and starter?
Do you have a DVOM?
Old 04-03-2015, 06:16 PM
yes, I think so. I'll check the earth and glow plugs tomorrow and let you know.
Its really odd.
Old 04-03-2015, 10:36 PM
drcjv's Avatar
drcjv drcjv is offline
Last year my 1572 would not start after it overheated. Water pump belt broke. I think I noticed pretty quick. Ended up that it needed a valve job. after valve job it starts and has more power than ever. From what I understand valve adjustment is very important for these engines to start and run.
Charles________________________
1572 3pnt, rear PTO, 50" deck
1772 3pnt 50" deck, Brinly Plow, 54" Power angle plow
1872 3pnt, 44" deck, Brinly Plow, 54" Power Angle Plow
2072 3pnt 50" deck, Brinly Plow
2072 50" deck
Cub Cadet Tank 50 Zero Turn
Cub Cadet 33" Commercial Walk Behind
1953 Ih Cub with just about every implement
New Holland TC33D with Loader and Backhoe
Old 04-04-2015, 09:13 AM
V30crewcab V30crewcab is offline
I would double and triple check your battery cables, and grounds. It sounds like a crappy battery connection to me. If it won't spin over fast, its not going build the heat to start.
1782, 1862, 1440(sold), 89 1050, 128, 70, some run some don't!
72 scout
IH 404 tractor
Old 04-04-2015, 10:28 AM
I've checked the battery connections today and all showing strong on the meter. I've also pulled the plugs and tested them and all good. So, I'm at a loss and running out of ideas.
Any further suggestions most welcome.
