Old 04-07-2015, 05:17 PM
swacor swacor is offline
I got the manual you sent me. Thank you for that it will come in handy. As for the parts I called my nearest ag dealer and got them on order. No more than 3 hours later the guy called me back and he said that he had the parts there the whole time. So tonight I'm going to work on that and hopefully get it running good again. One question I have is there a float adjustment on the command carb. I didn't see anything on that.
Old 04-07-2015, 05:21 PM
Been a while since I've done one of those, but I believe they have a plastic float. So, no adjusting them. Hang the float and flip it over. If it hangs level, your good. If it goes too high, then get a new float.
Old 04-08-2015, 10:46 PM
Well I got the carb kit in, removed the fuel tank and cleaned out, put new bushings in and cleaned the shuttoffs. I also put new line in all around. It definitely runs way better but seems like it is kind of laboring. I'm still not sure about the screw on the backside (rear) of carb behind shutoff solenoid. I've turned it out from closed to 1 to 2 1/2 turns out. Is there something I'm missing. Any advise please.
Old 04-09-2015, 10:33 PM
I still haven't got it right. I've tried everything I can think of. Its starts up and idles good then it all of a sudden stumbles. If I pole the choke out a pinch while it stumbles it straightens out but if I leave it out its almost like it gets to rich then I have to push the choke back in. After that it seems to stumble again after a few seconds. It just seems erratic and not right. Is it possible to get that transfer tube backwards (the tube that goes from upper to lower housing) The service manual shows its position different than the parts diagrams show.
Old 04-09-2015, 11:26 PM
Do you have a vacuum leak?
You could have something wrong with your assembly, but I would think the issue would be more consistent. I also wonder if you don't have a weak coil. If you take the carb apart again, post some pics. Otherwise take a video of it running and post it to a hosting site (Youtube or equivalent) and lets hear how this thing runs.
Old 04-10-2015, 11:56 AM
Heres a couple of pictures of the new plugs i put in.
Old 04-10-2015, 12:12 PM
Looks to me like one side is rich, the other lean. I'd be looking for a vacuum leak.
Old 04-10-2015, 12:28 PM
Where would the leak be coming from. I did a compression test and came up with about 160 on the starter side and that's where the rich plug came from and 170 on the other.
Old 04-10-2015, 12:39 PM
A vacuum leak would be between the throttle plate and the intake valve. Wouldn't affect compression, so that is no way to test for a vacuum leak. Check the manifold for cracks, gaskets for leaks, carb for leaks..... you'll have to look.
Old 04-11-2015, 06:18 AM
mickb72 mickb72 is offline
Hi, i think you might have a bad head gasket. Mine ran just like yours and the plugs looked the same. It was on the right side, setting on the tractor. After seeing the bad one i changed them both. Replaned the heads flat. Mike
