Old 05-05-2015, 04:44 PM
The 1810 takes a 925-3026 Ignition Switch. Although the switches "appear" the same, the terminal arrangements are in the same orientation....BUT.....totally different internally. Two different animals altogether.
Get the right switch and you will be happy.
Old 05-05-2015, 07:03 PM
Grand Pops 1810 Grand Pops 1810 is offline
More proof. I pulled the new switch this eve, and closely compared it to the old one. While the spade pattern was the same, the base of the spades were riveted in different locations.
I could see corrosion that could have bridged the base of 2 terminals, so I got out a wire brush and contact cleaner and decided to retry the old switch just for kicks. When turning the switch on, the oil light did not light, and there were no other signs of "life", but the fuse held without blowing. I then decided to jumper the solenoid again with the old switch in place, and the Magnum 18 sprung to life and I mowed. I'll locate the proper switch and update if this results in a complete fix. Thanks guys!
Now maybe Jonathan and crew can help me troubleshoot my Wi-Fi!!! LOL!
Scott
Maryland
Old 05-07-2015, 06:01 PM
Well I may not have gotten to the bottom of this yet. Now with the bad ignition switch still in place, I can still jump start the motor with the key in the run position. But now the PTO doesn't work. I see the red lead from the S terminal on the ignition switch feeds power to the PTO switch, so this could still be the bad ignition switch giving me trouble (or I have really bad luck).
Scott
Maryland
Old 05-07-2015, 06:55 PM
There are two different wiring diagrams for the 1810, depending on the chassis serial number range. What is your chassis serial number...???
Old 05-07-2015, 07:02 PM
Bingo, we have a winner. Here's the deal, you more than likely have a used up worn out switch. It's only about 30 years old and it should go for at least another 20 years but it is what it is. Let us know what happens when you replace it with the proper new switch. Only other suggestion I can give you is to get a copy of the wiring diagram and a test meter and have at it. Sorry if I sound like an A-hole to you.
Old 05-07-2015, 09:26 PM
Sam, I do have a test light and a schematic, so if I find time before the new switch arrives, I may start testing. Had to do a radiator flush on one of the cars after work this evening instead. Too many irons in the fire...
I don't think you're an A-hole. I appreciate very much you and the guys helping me, I stumble much less with your guidance. And I'm not the sharpest knife in the drawer (even getting duller as I age), so I'm sorry if my slowness to pick things up irritates some of you. I'll try and rant less and keep my posts more to the point.
R Bedell, good to know about the 2 different schematics, I'll have to check my chassis serial number... Thanks!
Scott
Maryland
Old 05-08-2015, 10:50 PM
The correct switch arrived in the mail today and was installed after work. Everything works proper now. Thank you Gentlemen!
Scott
Maryland
Old 05-09-2015, 06:39 AM
AH....it is always good to use the correct parts.
Old 05-09-2015, 07:06 AM
Glad you got it running.
