Old 05-08-2015, 10:48 PM
snoel's Avatar
snoel snoel is offline
Looks like one head bolt, still in it.
Steve
Old 05-09-2015, 08:08 AM
Are you trying to do this in the tractor with the tin work still in place? Why do you have the top of the carb removed? Did you do a compression test? If so what were the results?
Old 05-09-2015, 08:32 AM
neilh419 neilh419 is offline
I had cleaned the carb. First and hadn't put it back together yet. And, yes. I don't have a garage, and don't want to take too much space up in this one, as it's not mine. I may have to just pull it out. I can't get the rear shield/tin? Off. On compression, I didn't have the tools, but when I started to examine head there was visible seepage.
I found a vanguard manual, looks like it only has the 4 head bolts. I'm pretty green, on anything after the basics. Im moving slow, just trying to learn and not screw it all up.
Old 05-09-2015, 09:36 AM
Well you need to remove the blower housing in order to get at the intake manifold bolts. That has to come off because it's bolted to the heads. That's probably why you can't get the head off.
Old 05-09-2015, 04:57 PM
Thanks, Sam. I'm beginning to think I'm one of those folks who shouldn't own tools. Got the heads off. Anything look strange to anyone, or do I just clean and start replacing gaskets/reassembling.
Case dealer has head gaskets for $15 each. Is that good?
Old 05-09-2015, 04:58 PM
Sorry. It only posted the one picture. I'll get more up soon
Old 05-09-2015, 05:06 PM
Exactly what I expected. It has been over heated because of the buildup on the cooling fins. Get us the numbers off the tag on the engine and I'll look up the parts for you. They have a couple different head gaskets all depend on the engine numbers. Last set I bought were about $6.00 each but they do run upwards of $16.00.
Edit: Hope you pulled the engine because if one head looks like that the other one is probably just as nasty.
Old 05-09-2015, 06:06 PM
Yeah, it's filthy! I believe the number on the engine is K-517004. Mower- model # 142-653-100. Serial # 823808. Thanks! You guys have no idea how much you have been helping me.
Old 05-09-2015, 06:24 PM
Engine will have a tag on it and it should have a number something like this.
351447-1180-A1 this is just an example of a Vanguard number.
Old 05-09-2015, 08:34 PM
Is this the tag (attached picture)? If so, 303447 - 0447-01 -
Tags
1641, lose power, pro, smoke
