Old 05-13-2015, 09:38 PM
With the key on and the points closed the neg side of the coil to ground should show 0 volts, when the points are open, neg side of coil to ground should show 12 volts.
If you do not show 12 volts with the key on and the points open, check to see if something on the neg side of the coil is shorted to ground. Look in the tech section and check the coil as described.
Old 05-15-2015, 07:18 PM
Rob Ach Rob Ach is offline
So picked up a circuit tester and and a digital multimeter
With key on and the circuit tester on the + coil to grd, light is on
With key on and start, the circuit tester on the + coil to grd, light is on
With key on and the circuit tester on the - coil to grd, light is off
With key on and start, the circuit tester on the - coil to grd, light is off
using the multimeter set to 200 ohms, and key on, it reads -172 from + coil to grd
using the multimeter set to 20k ohms, and key on, it reads 8.5 from plug wire hole to grd.
Not sure if any of this makes sense. Does this confirm it might be the coil? thanks for any and all suggestions.
Old 05-15-2015, 08:33 PM
ironman's Avatar
ironman ironman is offline
For the moment, forget anything about reading ohms.
All that matters, whether with the test light or the meter, is that you see 12V at the pos side of the coil with the key in the run and start position. That is good.
Next, As I tried to explain earlier, what you should see on the negatives side of the coil depends on whether the points are open or closed at that particular time. So, with the key on, measure (or test light) the negative side of the coil and turn the engine by hand far enough that you can see the points open and close and tell us what you measure (or the light does) as they open and close and let us know.
Old 05-15-2015, 09:07 PM
Key on, Points closed, from neg coil to grd, light out
Manually turn engine
Key on, Points open, from neg coil to grd, light out
Coil? Points?
Old 05-15-2015, 09:17 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
points, clean them, or if you haven't replaced them , replace them. when the points are closed the light should be on, open it should be off.
Old 05-15-2015, 10:15 PM
So the points looked to be in pretty good shape. The contact surfaces didn't appear to be pitted but I still lightly sanded them. With the key on and points closed, neg coil to grd is still unlit. Does this point then to the coil?
Old 05-16-2015, 08:08 AM
ironman's Avatar
That is incorrect!
When points are CLOSED, light is OFF.
Anyways, next step:
Remove both the wire to the points and the condenser wire from the negative pole of the coil. With the key on, what do you see on the negative pole of coil??
If you still have no light, the coil is bad, try another coil.
If you now have a light, first try touching the condenser wire to the negative pole of the coil. If the light goes off, the condenser is shorted. If the light remains on it is probably good.
Next, rotate the motor by hand to a point where you can see that the points are open. Now touch the wire from the points to the negative side of the coil. If the light goes off either your points are shorted or the wire from the negative side of the coil to the points has a bare spot and is touching ground.
Old 05-16-2015, 09:48 AM
dvogtvpe's Avatar
you're right. I wrote it backwards, just leave the point cover off, with points closed , flick the points open and closed with your finger. light should blink on and off.
Old 05-16-2015, 10:50 AM
Smile
there was no light and the coil was bad,
Sourced locally was very expensive but the growing grass and weeds waits for no man.
Just wanted to say thank you!!! for everyone's advice and direction
Old 05-16-2015, 11:23 AM
ironman's Avatar
Glad to help.
