Old 05-23-2015, 07:34 AM
mv7fd mv7fd is offline
The problem was way before re wire. About two weeks ago it was sitting running and the RPM'S shoot way up and then it died. After that it's been acting weird
Old 05-23-2015, 07:41 AM
Why don't you start all over, tell us what the actual problem is and what actually happened. Then tell us what you have done to it since. This middle of the story, then the beginning .... that doesn't help you, or us.
Old 05-23-2015, 08:04 AM
It was running fine. I was letting it idle and the RPM'S ran way up and then it shut off. Since then, I can get it to start for a couple seconds but it won't stay running. I can get it to run a little longer if I hold the starter button, but as soon as I let go it shuts right off, like dead stop. I replaced the generator and the key switch and the wiring
Old 05-23-2015, 08:15 AM
I also have to keep the battery charger on it to get to to start battery is brand new. Seems like something is making it turn over real hard.
Old 05-23-2015, 08:29 AM
cubs-n-bxrs's Avatar
Sounds to me like you have a couple things going on. 1. If the RPM's shot way up it sounds like you have a problem with the governor. Might need to be reset. 2. Or possibly a bad coil. And no they cannot jump time like a car. If you think it's losing power to the coil put a volt meter on the 12v side of the coil and start it up.
Old 05-23-2015, 08:35 AM
Just went out and ran a wire from the battery straight to the coil still the same problem. I also tried to hit it with starter fluid to keep it running that didn't help
Old 05-23-2015, 08:58 AM
There's not a lot left then. The problem is somewhere between the coil and plug. Spark plug, plug wire, points.
Old 05-23-2015, 01:01 PM
Ok.... you have two threads going for the same problem.
http://www.onlycubcadets.net/forum/s...ad.php?t=39009
Lets pick one thread or the other for the issue please.
It is not the S/G or the regulator or the starter button. It's an engine problem so lets use the other thread. Thank you!
Old 05-23-2015, 10:20 PM
C5rider C5rider is offline
Just a quick thought, and hoping not to muddy up the water.
But, what about the condenser? Sounds like there's been a lot going on with wrenches on this "O". Without a working condenser, the engine will fire, but shut off very quickly. They seldom go bad, but perhaps it isn't connected? Maybe the wire is split?
Not sure if that would make it rev up, but it sure would make it die down.
Take it slow, and as some said, check out the manual and don't just throw parts at it. Solve it systematically. Takes time, but you'll get it, and you'll gain a little more info about your tractor. Good luck!
