Old 05-27-2015, 11:54 PM
Group_44's Avatar
Group_44 Group_44 is offline
The rear is out of the tractor and apart, I found very little water in the oil, maybe a teaspoon in the whole thing, most was in the axle tubes. Other than the broken bolts it is in good shape. No cracks on the case or axle carriers, bearings are good, no metal in the sump. Three mount bolts are broken off flush with the case hopefully with a little heat to release the threadlocker they will come out.
2082 w/60" Haban Deck & 450 Blower,AGs,weights
2084 w/54" Deck & 451 Blower
2086 w/54" Deck, 54" Haban Snow Blade
1864 w/54" Deck and weights
1641 w/48" Deck
1650 w/44" Deck parts Tractor (getting smaller all the time)
445 John Deere w/ model 40 FEL (went over to the dark side)
Old 05-28-2015, 07:28 AM
I have had good luck welding a washer to the broken blot and then welding a nut to the washer.
