Old 05-27-2015, 06:46 PM
If you have everything set up right.........I can do it in under an hour.
OK, that's better. Someone has to bust on you so it may as well be me.
I cheat I have all the cool tools to do it the easy way.
Old 05-28-2015, 08:36 AM
RedCC RedCC is offline
Originally Posted by Roy Najecki View Post
Just curious, about how much time did it take you to pull the engine? And can it be done alone? I really should pull the Magnum out of my 782 to replace head gaskets and track down an oil leak but given my wife's health condition I don't think she can help me very much.
I'd say a couple hours and only because I was careful keep track of all the hardware and such. I lifted the engine off the frame myself. Not too bad and would be much quicker the second time. That being said I did find the rear seal the source of my leak. I was able to hold the flywheel by hand and loosen the bolt. It also came off the shaft nicely with little pressure from the puller. It was well lubricated! Now to find a seal and get this tractor back to work. 002.jpg
Old 06-01-2015, 08:56 AM
Happy to say the 782 is back in service! Side benefit is how much cooler it runs now that all the oil from the inside back of the jugs and stator is gone.005.jpg
Old 06-01-2015, 08:15 PM
Redblower's Avatar
Redblower Redblower is offline
Nice work, glad you got it going again and it didn't do any real damage.
Vic
Old 06-02-2015, 06:59 AM
Roy Najecki's Avatar
Roy Najecki Roy Najecki is offline
Other than cleaning the engine and replacing the rear seal, did you do any other work to it while it was out? I was thinking along the lines of also replacing the front seal and decarbonizing the cylinder heads.
Old 06-02-2015, 08:03 AM
[QUOTE=Roy Najecki;331553]Other than cleaning the engine and replacing the rear seal, did you do any other work to it while it was out? I was thinking along the lines of also replacing the front seal and decarbonizing the cylinder heads.[/QUOTE
Just to clarify what I was incorrectly calling the "rear" seal (referenced to the tractor) was actually the front seal. Flywheel is front and PTO is rear. So I could service the PTO end while the engine is in the tractor easily. I passed on cylinder heads only because compression is 130/125 psi and I needed it back in service asap. I did buy both genuine seals locally for $12.50 each. Head gaskets were quoted as $26 each though. I really should buy those for the future know they are available. Is that too much?
Old 06-02-2015, 08:09 AM
Vic
Yeah, you talk about getting away with one! If I hadn't driven back past that spot where the tractor warmed up and noticed oil in the grass I'd be singing a different tune right now. My buddy who excavates says to me "always be looking for a blood trail" behind your equipment. And I will.
Old 06-02-2015, 02:55 PM
The logic for determining which end of the engine is front and rear does seem odd. Anyway, I've heard it is common for that seal to develop leaks. Mine leaked nine years ago and it might need another seal now.
