Old 06-10-2015, 01:49 PM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
Also run the newest tire you can find.
And stretch wrap them air tight after each day or two of use till the next time used.
Old 06-10-2015, 06:44 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
Originally Posted by Frank in Foresthill View Post
Find an older wheel that is narrower than yours. Say a 23x900.
Put some sheet metal screws through the wheel into the beads.
Lower the air pressure to about 2-3 Lbs.
Makes a bigger footprint. Old drag racing trick.
that theory don't really work to good in pulling. as the tire squats down you lose to much drawbar which will cause traction and balance problems.
Old 07-12-2015, 07:06 AM
Wbrech Wbrech is offline
Just an update. First pull I ran 10 pounds pressure in a stock turf tire with fifteen pounds on the nose. Didn't do bad but marks on the road showed needing more air. Second pull fourteen pounds in tires put me in top ten. Third pull fourteen in rear tires and all the weight on the back with an empty nose sent me to the end of the track and got me $100 and a trophy. Thanks for all the help on here guys!
Old 07-12-2015, 08:39 AM
dvogtvpe's Avatar
good job!!
Old 07-12-2015, 03:02 PM
austin8214's Avatar
Awesome!!!!
