Old 06-02-2015, 05:17 PM
jimbob200521's Avatar
You got the part that it calls for. I'd still take your old belt to TSC and get a couple that are shorter than what you have. I just went through the same deal on one of my 2182's with a 60" Haban. I was basically Bush hogging with it, something that I know is wrong and picked up a branch that caused the PTO belt to jump off the deck pulley. Long story short it destroyed the belt so off to TSC we go pick up 3 different size belts and use the one that fits the best. The supposed Cub size and what I ended up using don't jive. BTDT.
Come on Sam, Cub's are built to take it! I have to say that because just last weekend I knocked down a friends yard that hasn't been mowed yet this year (it's best if you don't ask but I'd say it was safe to say it was some yard bush hoggin ) and found a nice what looked like metal brick. The deck shot some sparts (leaving a few nice dings in my new blades, I'm sure ) but rather than throw the belt off the deck pulley, it somehow tripped the mule drive tension relief arm. That took tension off the belt and let the deck stop without hurting the belt or deck. I wondered what the heck happened. Hopped off the tractor, released the arm, and I was back in business.
Anyway, I think some of the Cub belts for these machines are a bit too long as well. Mine is right on the edge of me wanting to replace it but it works fine so I figure why fix it if it ain't broken. AND it was a royal PITA to get on, like if it was any shorter I couldn't have gotten it on. But I digress...anywho, I have seen more than one Cyclops mule drive with a heat spot on it in front of the right pulley (when looking at it from ahead). I'm sure some were operator error but still; makes ya wonder
-Ryan
Did a little more digging, they show the belt part number for the later serial number tractor that has the larger PTO but they don't show the belt number for the early tractor with the small PTO pulley. What is the serial number of your tractor? Just thinking if you have an early 2082 and bought a late style belt that explains the problem.
Old 06-02-2015, 06:56 PM
Diesel Krazy's Avatar
Diesel Krazy Diesel Krazy is offline
I have the same problem with my 2182 and 60" Haban. My cub Cadet belt is too long also.
Original- Wheel Weights, AG tires, Brinly Sleeve Hitch, #2 Cart
882- 50c Mower Deck
2182- 60c Mower Deck, Rear PTO, Cat 0 3-Point, Brinly 60" rear blade
Case 646 FEL
Case 446
Old 06-02-2015, 07:24 PM
OK....after a major PITA search.....I found the answer
Use belt: 954-3001 for 2082's with S/N range: 800,000 - 821,059
Use belt: 954-3047 for 2082's with S/N range: 821,060 - 836,000
954-3001 is: Sec B x 91.7"
954-3047 is: Sec B x 95.3"
I am guessing you need 954-3001
Old 06-02-2015, 07:48 PM
Use belt: 954-3047 for 2082's with S/N rnage: 821,060 - 836,000
OK I looked in Parts Tree and the Cub site, I just want to know where you found the answer?
Old 06-02-2015, 07:50 PM
I am ashamed to say........I was unfaithful..........I went to the PartsTree site.
Old 06-02-2015, 08:11 PM
Some how I missed it on the Parts Tree site. All I found was the different PTO's and that was a clue for me. Gotta love it we have to play detective to figure out what belt to use. Can't blame to OP on this one.
Well congrats on finding the answer Dr. Roland.
Old 06-02-2015, 08:15 PM
I must confess.....(A) it was a major PITA. (B) I only stumbled across the answer by accident, and (C) Cub Cadet sure could have done a whole lot better at referencing or explaining this one.
Old 06-02-2015, 09:36 PM
unklechuckles19 unklechuckles19 is offline
Sorry for the late reply guys, was at the firehouse after work. I have a late model 2082, 827060. I'll be popping the belt off and stopping by TSC or my electric motor guy (who has a million different belt's in stock) to find one that fits better.
I'm curious, where did you look on parts tree? I did a quick look this morning but couldn't find the belt in question on any of the drawings. I must have overlooked it, or not dug deep enough to find it.
Thanks again guys!
Old 06-02-2015, 10:24 PM
Unklechuckles, if you have the later machine then you have the 6" pto which takes a larger belt then the 4.6" smaller pto on the early machines. Can you measure that or shoot us a pic of it? Maybe someone changed it and put the wrong one on it. And you prolly should measure the deck center pulley also to see if it has been changed. The belt you picked up (954-3047) is a B section belt that is 95.3" long. Don't put a standard V-belt on it because all the twisting and turning will overheat it and destroy it quick. The TSC box store is your friend here. Go buy multiple belts, find what fits and take the rest back.
